50 lb injectors and mass air flow sensor
Old December 29th, 2007, 02:55 AM   #1
mustank's Avatar
2001 mustang
mustank is on a distinguished road
would 50 lb injectors and a mass air flow sensor do anything for my car if i only have a trick flo upper plenum and cold air intake and slp loudmouth cat back on my 4.6
Old December 29th, 2007, 03:06 AM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
U don't need new injectors. The stock ones will be fine with a lot more than you have done. 50lb injectors are for like 900hp FI motors.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old December 29th, 2007, 03:07 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
A bigger mass air meter will help especialy if you have a nice cold air intake.
Military Crew
U.S. Army Aviation
Old December 29th, 2007, 03:16 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
do not worry about replacing injectors unless you build. they will hold around 330 before you max them out. as for maf, a c&l 85mm will be a great mo. no need for an 90mm or anything, no way to utilze it without boost.
Old December 30th, 2007, 06:20 PM   #5
mustank's Avatar
2001 mustang
ok so tha mass air sensor will help me out though
Old December 30th, 2007, 07:36 PM   #6
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
yae and then get it tuned, no on the injectors uneeded for the mod you have a CAI would also be good.
Old December 31st, 2007, 03:10 AM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
if you get a c&l, just have to get the sample tube for your injector size. stock injectors will hold in the range of 330rwhp before maxing out, all depending on set up and tune. i am running a c&l maf and inlet and absolutely love it! a 90mm lighting maf is not needed, you wont really see much gains and will have to have a tune done.
Old December 31st, 2007, 10:46 AM   #8
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
no offense but from all my experiences C&L are junk stay away from them.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old December 31st, 2007, 11:31 AM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
what was your bad "experiences"? i have had nothing but good with c&l, and highly recommend their products.
Threads Similar to: 50 lb injectors and mass air flow sensor
24lb mass air flow sensor poisonstallion95gt 94-95 6 November 6th, 2007 03:20 AM
mass air flow arice 94-95 2 March 30th, 2007 12:12 AM
cobra mass air flow sensor 02NEBstang 99-04 3 March 5th, 2007 08:39 AM
so what do i look for whrn getting a mass air flow sensor gordon norris 5.0 Mustangs 5 February 27th, 2007 03:07 AM
Cleaning the Mass Air Flow Sensor IcantDo55 5.0 Mustangs 10 June 26th, 2006 12:20 PM
