Rear Break Issues
Old September 12th, 2006, 12:44 PM   #1
Look Ma! My First Post!
EmeraldSVT is on a distinguished road
Rear Break Issues
I just recently purchased a 1997 Cobra coupe and decided to do a brake job. Had no probelms at all with front change, but the rear ones have given me fits. I purchased the universal adapter for a 3/8 ratchet, and after over 2 hours felt certain that the piston was bottomed out. After multiple attempts I was unsuccessful in getting the caliper to clear the new pads. Any suggestions, tips, tricks would greatly appreciated.
Old September 12th, 2006, 01:05 PM   #2
the rear calipers can be a bear sometimes to compress. try pushing in on the tool while turning it. Also, make sure the parking brake is released
88 Mustang Coupe
www.rickscarcare.net
Old October 2nd, 2006, 04:52 PM   #3
Fryrice's Avatar
Fryrice will become famous soon enoughFryrice will become famous soon enough
Go to Advanced Auto and rent their Master brake kit. Its a $100 deposit and you can keep it for 45 days and get your deposit back. Its easier to use,because it helps you create pressure while rotating the piston.
Dont overtighten the piston,or you can cause damage elsewhere. Did you take the cap off your master cylinder ? You have to relieve the pressure at the other end for the piston to turn correctly.
Fryrice has left the building.
Threads Similar to: Rear Break Issues
trying to break 100 HMUSN The Clubhouse 26 April 2nd, 2008 10:08 PM
Will this break anything? 06RedfireGT The Clubhouse 12 November 10th, 2007 12:28 AM
break in time? Dennis General Tech 6 August 7th, 2007 12:20 AM
Break in jonnotch 5.0 Mustangs 7 May 27th, 2007 08:39 PM
Break my rear Axle EZ8911 2005 - 2010 18 April 20th, 2007 10:52 PM
