Mustang problem
Old January 14th, 2008, 11:12 AM   #1
Mike73's Avatar
Mike73 is on a distinguished road
Mustang problem
I have a Mustang GT ´01 and have a really big problem right now. On the weekend it ran only on 7 cylinders and I brought it in the shop. They made a diagnostic and after that they told me a ignition coil broke down. If they should fix it, it will cost me 350$. Ok, do it I need my car. They started the engine with the new coil and after 2 minutes the coil next to new one blowed up and smoked. Now the guys from the shop thinking there`s a cable problem. If I drive the car anymore it`s possible to destroy more coils or the computer.
Knows somebody more about this problem?
Thanks
Old January 14th, 2008, 02:26 PM   #2
putermech's Avatar
1999 GT Black Coupe
putermech is on a distinguished road
Replaceing the coil is a "do your self job"...5 minutes or less...Don't lose the small rubber seal inside the connector.
Remove the coil pack and see if you have water build up. Die-eletric grease will fix that. If you replace the coil pack...stick with oem unless you replace them all at the same time.
You may also want to replace the spark plugs as they may have issues.
5 Speed w/ Trac-control
Threads Similar to: Mustang problem
My Mustang Has A Problem ToMuchHxc V6 Mustangs 12 December 29th, 2007 10:21 PM
Mustang problem mikerm125 96-98 2 September 10th, 2007 10:51 PM
New Problem With The New Mustang Already... KIMMER 2005 - 2010 11 December 3rd, 2006 01:25 PM
Problem when starting my Mustang?.. Chris02 99-04 11 November 30th, 2006 12:15 AM
95 Mustang Over Heating Problem lil_homie69 V6 Mustangs 2 October 27th, 2006 07:12 AM
