Opinion needed
Old January 14th, 2008, 11:33 PM   #1
1997 mustang GT
1bad281 is on a distinguished road
Opinion needed
I have the opportunity to buy a Lincoln LSC 4V for 700 dollars complete with the computer and everything. Does anyone know what is special about a LSC engine. I was told it is a higher Horsepower engine then a regular mark Vlll motor. I dont know much about 4V motors since i have a GT. thanks to all who reply
james
Old January 18th, 2008, 12:39 PM   #2
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
1998 Lincoln Mark VIII 2dr Cpe LSC
Gas V8 4.6L/281 290 @ 5750 RPM 290 @ 4500 RPM 2000
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old January 18th, 2008, 08:03 PM   #3
1997 mustang GT
thanks for the reply chris..... so those have less horse then a 98 cobra..... whats the difference between that and the 98 cobra motor. anybody know.
Old January 19th, 2008, 08:56 AM   #4
2003 Ford Mach
I know for a fact that those have less Hp. The cobra is said to have 305.
The 4.6L 32-valve DOHC V8 engine was an all-aluminum variation on Ford's Modular engine, in all model years.
The DOHC 32-valve 4.6L V8, rated at 280 hp, came with a distributorless coil-on-plug ignition system, eliminating the use of high voltage spark plug wires. Some of the transmission internal parts were reinforced in the late 1997 models and all 1998 models. LSC models had firmer shocks and larger anti-roll stabilizer bars, for better handling and control, a lower gear ratio and true dual exhaust giving a 10 hp boost taking it to 290 hp.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Threads Similar to: Opinion needed
Head Light and Tail Light Opinion Needed Laser Visual 8 January 2nd, 2008 02:16 AM
Opinion..... AnglicoGT98 96-98 1 October 18th, 2007 09:48 AM
need ur opinion Steve O 99-04 19 May 27th, 2007 04:49 PM
Cam, professional opinion needed... Modern_Muscle 2005 - 2010 12 May 21st, 2007 01:55 AM
your opinion needed. patwrecked General Tech 6 May 16th, 2007 01:56 AM
