Prob passing inspection with exhaust
i have a 96' mustang gt 4.6L and i have a flow master dual catless custom exhaust and its throwing out three different codes when i go get an inspection sticker..they are as follows p1443,p0401,p0174...anyone have any clue what these are and what i can do to get an inspection sticker without havin to put cats on it...i tried the MIL eliminators and they didnt work
2003 Ford Mach
Traveling at the speed of a photon
P0174 means youre running lean.
P1443 Evaporative Emission Control System--Vacuum System, Purge Control Solenoid Or Purge Control Valve Malfunction P0401 (EGR Flow Insufficient) By the way welcome!!!
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
ok but how do i get rid of all those codes?...Thank You!
48.47@ 12.58
do you have mil eliminators?
yea it didnt work
2003 Ford Mach
lean running condition means that the air/fuel mixture is unbalanced, and that the engine is getting either too much air, not enough fuel, or a combination of both. You might need to get a tuner to fix that!
As for the egr idk if you can somehow clean it or just replace it. That there should solve the problem. ![]() oh oh and for the p1443 code. see if you can follow this. "this came from another forum". Your egr is your Exhaust Gas Recovery. The valve itself looks like a flying saucer. The solenoid is a small, around 3" x 2", rectangular box with two rubber hoses and an electrical connector. Those rubber hoses and a tube off your EGR valve both hook up to your right exhaust header. Both are mounted on the back right corner of your upper intake manifold. Try getting a can of elctric cleaner and clean the electrical connector and replace or clean the rubber tubes.
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] Last edited by chris1; January 19th, 2008 at 10:50 AM. |
whats the best type of cats i can buy that wont take the sound away from the custom exhaust i already have on there thats only 2 months old and do u know anyone that sells them??
48.47@ 12.58
i would buy a stock mid pipe and slap it on before testing and then just take it off after.
Threads Similar to: Prob passing inspection with exhaust
| Passing Along Happy Thoughts | WAR-PARTY | The Clubhouse | 4 | November 16th, 2007 04:38 PM |
| Passing Emissions - 87 LX Auto Mass Air & E303 Cam | pyrofenix | 5.0 Mustangs | 4 | November 12th, 2007 05:08 PM |
| NJ inspection | HessiaN257 | Northeast | 1 | September 7th, 2007 04:17 PM |
| Passing Emissions | RandoGT | General Tech | 17 | June 27th, 2007 01:43 PM |
| Passing emissions tips | Bill | General Tech | 8 | March 11th, 2006 12:57 AM |
