Discussing EGR Not Completing in the Modular Mustangs Forum. I have this problem with my 96 mustang gt. I have replaced all parts that ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
EGR Not CompletingI have replaced all parts that run off the EGR system and still the EGR does't clear... I have check to see if I had a leack somewhere in the exhaust system but didn't find any. Is there something I am missing to check? If someone can guide me in the right dirrection that would be cool.. Thanks guys..... |
egr valve
if its still not clearing check the intake for carbon buildup mine had about an 1/8 of an inch of build up around the hole were the egr mounts up also check the pipe that connects to the rear of the egr it could bel stuffed up try using some carb cleaner and blow it out with some kind of pressure like an air hose to c if it will blow trough . thats some of the restrictions that I have had problems with.
I will check to see if that will work. I will get back to you on that one. thanks alot man
Checked the egr for build up and it was pretty nasty and also checked the pipe that connects to the egr and goes down to the manifold It was cloged up and got that cleared out and put back together and still nothing. I was like that should do it and it didn't. That sucks..
Anthting else i should check? Thanks for the help man.. |
I have h-pipes on the ride and have mil elimnators on the back o2 sensors do you think if one back o2 is bad would not the egr system do what is being done.( EGR system not completting)? Just a thought i don't know..Someone has told me that maybe that could be a problem...Anyways don't know about that part....Thanks again
Do you think that the egr pipe may still have some carbon build up in it that it's not functionig still?
#7 | |
what do you mean by not clearing ?
White99stang-
93 LX, H/C/I + Vortech |
All it says on the scanner that my egr system is not complete.
There is no code that comes up to trigger the check engine light.... |
#9 | |
You scanner says the system is not complete, as in the drive cycle hasnt been completed. Or as in the check engine light stays on ? If it stays on there is no code ?
White99stang-
Yea it just says that the egr system is not complete..No codes that come.
I was just woundering if it would efect my inspection when it's time to get it...Normally it would say all complet on everything... |
#11 | |
Do you have a handheld programmer on this car at all, to where you have bypassed the EGR ? I know some handhelds you can delete the EGR./
White99stang-
Not on this one....
That would be cool if it did....LOL |
Have a hand held scanner but it wont deleat the egr.
Threads Similar to: EGR Not Completing
| EGR Not Completing | mustangblk96 | General Tech | 4 | September 19th, 2006 11:00 PM |
