Discussing 4v Swap People Look in the Modular Mustangs Forum. Has anyone done a 4v swap and not tuned the car and kept the stock ...
Old January 22nd, 2008, 04:21 PM   #1
03GT_Hybrid's Avatar
2003 GT/ 4v Swap
4v Swap People Look
Has anyone done a 4v swap and not tuned the car and kept the stock ECU of the GT. I have been having problems at the top of my 4th gear and I dont know what it is and it is driving me crazy. Thanks
2003 GT
1999 4v swap
Full Bolt ons
Old January 22nd, 2008, 08:39 PM   #2
MuchCoolerThanGTsetGO
ChrisJ's Avatar
SLOW
You need a tune bro...
Before you have to put a new engine in there...
Whats it doing in 4th?
You can get a chip and have the tune burned on there and use your GT PCM...
My Junk
www.myspace.com/cjobe
Old January 22nd, 2008, 09:11 PM   #3
SoMuchCoolerThanChiaGutt
GTsetGO's Avatar
12.88 @ 112
+1 what exactly is it doing?
Have a WHITE99 kind of day.
www.myspace.com/gtsetgo
www.myspace.com/philfriedman
www.myspace.com/robsidea
A hard-on doesn't count as personal growth.
Old January 22nd, 2008, 09:49 PM   #4
2003 GT/ 4v Swap
For lack of a better choice of words it "crapped out on me" I was doing a pull on the highway and twice in 4th the motor sputtered at like 4000 RPM or so and it felt like I let off but I didn't. It was wierd so I am thinking about getting the SCT Pro Racer Package and a wideband and tuning it but I want to see if there are any mechanical problems. I checked that none of the wires are melted cause I dont want an electrical fire. And a while ago it was like doing the same thing in the exact same place in the RPM range in 4th but it was never so bad that the engine gave up. If you have any info please help. I need to get back out there and go fast!
2003 GT
1999 4v swap
Full Bolt ons
Old January 22nd, 2008, 09:54 PM   #5
ChrisJ's Avatar
SLOW
You need to get a tune before you blow that engine sky high...
Im serious...
$10 says it is lean as a mofo...
My Junk
Old January 22nd, 2008, 11:09 PM   #6
2003 GT/ 4v Swap
Yea I am going to take it easy for a while. I have a cobra pump and 24 lb. injectors. If anything I think I may be a little rich but idk. I want to get a wideband before anything. Any suggestions? I was looking at autometer.
2003 GT
1999 4v swap
Full Bolt ons
Old January 23rd, 2008, 06:00 PM   #7
Im serious...
+1...i'll put down $50 on the table.. Its's not about the pump and the injectors...The computr's not telling it to inject enough fuel because it's on the GT's tune. The GT's tune is designed for heads and an intake that flow significantly less, therefore, it would require less fuel...The computer doesn't automatically know that the engine's pullin more air. The MAF sensor can compensate some, but only so much. I wouldn't rely on that.
Old January 23rd, 2008, 08:15 PM   #8
Captain Of Team Leg Hump
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
+1 That motor isn't going to last long with out a tune.
Bassani Crew Member #1
Better to be judged by 12 then carried by six.
Old January 23rd, 2008, 10:05 PM   #9
2003 GT/ 4v Swap
Ok, I am also throwing codes for no air intake temp sensor. Is this a problem cause I could se ehow that would affect the spark. I am going to get the SCT Pro Racer Package as soon as I can but I am working 2 jobs and still am not getting money fast enough! lol
2003 GT
1999 4v swap
Full Bolt ons
Old January 23rd, 2008, 10:07 PM   #10
ChrisJ's Avatar
SLOW
Yes you need to get an IAT in there...
IAT - Intake Air Temp
It tells the PCM when to pull timing and such because of the temp of the intake charge...
My Junk
Old January 24th, 2008, 07:35 AM   #11
2003 GT/ 4v Swap
How do I get one in there?
2003 GT
1999 4v swap
Full Bolt ons
Old January 29th, 2008, 11:22 AM   #12
99cobradroptop's Avatar
99 Cobra Vert.
I'll bet $100 its running leaner than S**t, think about it, you went fron 2v to 4v, you need more fuel for the added valves and since your comp. is still running like a 2v. its starving the motor at high rpms. Just my opinion
JLT RAI, MAC LT's, bassani o/r X, M55's , Eibach Pro-kit lowering springs, eiback front and rear sway bars, solid axle swap, 31spl strange axles, 31spl diff. 3.73 gears, Pro 5.0 shifter, MM Full Length Subframe Connectors
Old January 30th, 2008, 01:55 PM   #13
subscribing...
Old January 30th, 2008, 08:25 PM   #14
ChrisJ's Avatar
SLOW
Take the two gray wires that were on the MAF and wire them to a Lightning IAT sensor and drill a hole in the intake for it to go in then put it in there and get an effin tune for gods sake
My Junk
Old January 31st, 2008, 12:34 AM   #15
1BADSTANG's Avatar
subscribed. Dude.. shits lean
331s burn oil and have a bad piston to head ratio.
http://www.StreetChallenge3D.com/sig...?referal=1BAD1
LOL @ THIS http://www.ihateyoujulia.com/?id=0a8...27aa2c6245e4c2
Old January 31st, 2008, 03:32 AM   #16
SSStang's Avatar
2k2 Mustang V6
Please don't drive that car anymore man... Or your gonna be looking at parts on the ground.
Selling for friend: Vortech Supercharge kit < 100miles.
Threads Similar to: 4v Swap People Look
Gun people.... please look Drgnracin72 The Clubhouse 54 January 1st, 2008 03:52 PM
come on people BROKINARROW 5.0 Mustangs 0 October 31st, 2007 01:56 PM
mad people WilltheThrill The Clubhouse 20 April 6th, 2007 04:01 PM
People! MSTGGT00 The Clubhouse 13 February 17th, 2007 05:49 PM
Is it possible to "Swap Tunes" with other people? 07BossGT 2005+ 6 February 13th, 2007 11:12 AM
