1999 GT Cam Question
Old September 27th, 2006, 07:53 AM   #1
franchise's Avatar
franchise is on a distinguished road
Newbie here needing some help. I ahve been doing some research on my next mod, comp cams.
I have a 99GT, manual transmission that is not my daily driver. I read where some people say the 4.6 sounds sick when the cams are upgraded.
There is a certified mechanic where I live that will do the job for $250 if he needs to change the valve springs, seems pretty cheap to me!
Now, what would you guys recommend? I'd like to keep it at around $600 if possible because of other upgrades I am also doing. Is this an upgrade that most people do with their stang? Thanks
patrick
Old September 27th, 2006, 07:55 AM   #2
mdvaldosta's Avatar
11.47@120.58
Springs are gonna cost around $150 - $200, plus $550 - $600 for the cams. Cams are awsome, good power gain (if you've got stock heads don't go with the biggest cams) and great sound. A good investment.
Old September 27th, 2006, 07:59 AM   #3
franchise's Avatar
I am keeping my stock heads for now. Would you recommend any particular brand?
Old September 27th, 2006, 12:42 PM   #4
Drgnracin72's Avatar
i am using comp cams in mine. im running a stage 2 but wouls reccomend a stage 1 with your heads. theya re around 580 bux and i do reccomend doing the springs also. my comps sound badass but the stage 1s arent gonna have a big lope. youll somewht be able to hear them but not extremely noticible. not a lot of poeple do them becasue they arent simple to do. but its a great upgrade and will wake your car up a little bit
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 27th, 2006, 01:05 PM   #5
franchise's Avatar
I talked to the guys at VT racing and with my setup they recommended the Stage 2 kit which is a 560 lift. They said that because I want the distinct, agressive sound. If I would go that way, would I have enough clearance over my existing pistons? I wouldn't want to bust off the top of my pistons!
My buddy has a 532 lift on his 5.0 and it lopes pretty good. I know they are totally different engines but the VT Stage 1 has a 540 lift.
Geesh, decisions!
Old September 27th, 2006, 02:05 PM   #6
i think poerformance wise, youd be better off with the stage 1 but if ya want the 2 for the sound, then go for it. youll have to do somehting different with the timing becasue you could get some piston to valve clearence probelms
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old September 27th, 2006, 02:16 PM   #7
franchise's Avatar
Well, I dont want any piston probs and I want the better of the performance, car already sounds good! Sounds like a stage 1 for me! Thanks!!!
Old September 28th, 2006, 08:19 PM   #8
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
vt and comp make great cams, I went with the guy in my sig for a custom grind. He asked me everything that had done to the car and what I planned on doing and made them for me for $750 with the springs.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old September 28th, 2006, 10:25 PM   #9
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
im running comp 262 cams in mine. buddy of mine has vt stage 2 cams. no ptv problems and sounds sick!
Old September 29th, 2006, 12:22 AM   #10
02Gt Stang's Avatar
13.6@102
02Gt Stang is on a distinguished road
Since were on the topic of cams, im planning on putting in a turbo, but before that i woudl like to put on a comp cam and patriot stage 1 heads, would this be worth it? NOt sure what you mean by springs.
Procharged 383 rwhp/ 391 rwtq
Old September 29th, 2006, 07:38 AM   #11
when we talk about springs were talking about the valve springs. the stock ones arent great fro bigger cams. the headds would do you good, but you should probably look for some turbo specific cams. i know for sure your going to want something has a wide lsa(lobe seperation) around 114-116 as so your not blowing boost out of the exhuast and wasting it.
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old October 2nd, 2006, 03:36 PM   #12
Fryrice's Avatar
Fryrice will become famous soon enoughFryrice will become famous soon enough
If you go with a stage 1 setup yo wont need a tune and you cankeep your stock springs.Stage 2 you will also need a tune which is costly along with new valve springs.
Depending on how much you wanna fiddle with the tune,stage 1 might be the way to go. Stage 2 will definately sounds deeper,but there are some drawbacks
Fryrice has left the building.
Old October 10th, 2006, 11:21 AM   #13
menedu is on a distinguished road
What kind of drawbacks with the stage 2? Can you elaborate on this subject?
-Ed
Old October 10th, 2006, 12:18 PM   #14
you need a tune whether you go with a stage 1 or a stage 2. anytime you change something in your engine, you need to have a tune for 1. to make it safe, and 2 to make it run well and take advantage of everything you can. there arent really any draw backs to the stage 2. you probably wont be able to use the power range with them becasue you shouldnt be revving your stokc shortblock that high. stage 1 on your car would be the way to go. youll be able to hear them a little bit but it wont be like the 2s. i suggest you do the springs no matter what you do. just preventing problems that could arise later on
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: 1999 GT Cam Question
1999 Mustang GT CyberPrey Modular Mustangs 6 November 6th, 2006 11:29 AM
Looking to sell my 1999 GT? Max02420 99-04 1 November 1st, 2006 02:19 PM
1999 mnky 99 gt 5.0 Mustangs 0 June 28th, 2006 09:50 PM
1999 redo curbut General Tech 3 May 5th, 2006 12:17 PM
