Slight Miss When In High Gear / Low Rpm
Old October 8th, 2006, 12:41 AM   #1
built54 is on a distinguished road
In regards to a 2001 6 speed 4.6 gt. When im around town, and im in a high gear, low rpm, and i give it gas, pretty bogged down, it misses sometimes, just once or twice before rpms climb. What do you think causes this? Should I start with plugs and wires?
Old October 8th, 2006, 11:45 AM   #2
probably a coil assembly or a spark plug.
88 Mustang Coupe
www.rickscarcare.net
Old October 8th, 2006, 11:47 AM   #3
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
Your car should not have wires...
Check the plugs...
Facebook
Google+
Old October 8th, 2006, 11:47 AM   #4
mdvaldosta's Avatar
11.47@120.58
Most of the time missing on acceleration is caused by something in the ignition system, as twist suggested. Though, yea your '01 GT has coil on plug so it's either a coil pack or plug. I'd look at the plugs first.
Old October 8th, 2006, 12:57 PM   #5
Sorry, I was meaning the bottom part of the cop. I might as well go with new plugs and some aftermarket cops. What do you guys use?
Old October 8th, 2006, 01:08 PM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
I am still running the stock COP's...But I run NGK plugs...
Facebook
Google+
Old October 8th, 2006, 01:49 PM   #7
what part number?
Old October 9th, 2006, 08:32 AM   #8
Drgnracin72's Avatar
if your gonna change the cop, go with granatellis setup. they run for less than $500 and they will make a huge difference, and an even more dfference on a blown or nitroused car. they are 10x better then stock but cost considerably less than the stock ones
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old October 9th, 2006, 09:58 AM   #9
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
I use NGK Tr-6...
Facebook
Google+
Old October 9th, 2006, 11:27 AM   #10
Yeah ive heard about those... I think ill just change the plugs for now, and later plans down the road of adding a kenne bell kit, i will then add granatelli cops!
Old October 16th, 2006, 12:22 AM   #11
Well I bought new plugs, and the boots for the cops, put them in, got it all done in about 30 min... Im used to changing plugs in the 5.4L trucks, so this was so easy! almost all the boots were cracked about an inch on the bottom... Now, I dont even know how to describe the power! I can burn them all the way through first gear now, and thats not dumping the clutch! Thanks guys for the help! I raced a cobra with a kenne bell this weekend, even through first, hit second and he flew by me like a jet!... I know what is going on this stang next!!!
Threads Similar to: Slight Miss When In High Gear / Low Rpm
Please Help With High Rpm Miss cptkng79 5.0 Mustangs 8 October 1st, 2007 09:54 PM
Had a slight accident 03_StangGuy 99-04 9 July 7th, 2007 01:37 AM
help me (high idle and miss) trouble8732 94-95 3 February 8th, 2007 11:41 PM
Slight Engine Knock? VegasGT 2005 - 2010 2 September 27th, 2006 04:18 AM
slight drop kanniiee General Tech 2 August 21st, 2006 02:37 AM
