HELP White Face Gauge Install!
Old March 27th, 2008, 05:22 PM   #1
97redgt is on a distinguished road
The gauge cluster is out and cover off but i don't know how to take off the needles to get the old gauge plates off. DId you guys cut them up or what? My new ones i think will slip over the needles. Is it ok for the needles to move? I've heard stuff about not correcting speedo needle... what should i be careful about???
steeda tri-ax, pypes catback & o/r x, BBK shorties, K&N cai, Full PI Swap, pro-m 80mm maf, 75mm tb and c&l plenum, steeda ud's, screamin demon cp's and ford racing 9mm wires, fox 4cyl front springs
260rwhp 290rwtq
Old March 27th, 2008, 06:09 PM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Well first of all you need to take off the needles but get a piece of paper and note where their locations are at idle. Wait 5-10 minutes so you know it has warmed up and all. You will be able to record the 4 smaller dummy gauges (except fuel that's not dummy) and the RPMs. The speedometer you will have to adjust either on a dyno or matching speeds with a buddy on the road. Use a fork or a couple of flathead screwdrivers to get the needles off. Oh and its not just the needles it is also the black circle that the needle goes into. So all in all you will have 6 needles with the base still attached when you get them all off.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old March 27th, 2008, 06:30 PM   #3
The electrical connecter peice for the center of the guages (tach and speedo) gets in the way of the engine heat guage...what do i do.
260rwhp 290rwtq
Old March 30th, 2008, 02:44 AM   #4
06z28eaTer's Avatar
2006 GT / 1999 Cobra
06z28eaTer is on a distinguished road
Send a message via AIM to 06z28eaTer
you may have to remove your 'factory' face or whatever, or you may have to glow your gauges down so the needles dont stick to it.
-2000 GT Vert-
Grabber Blue Paint, Cervini Stalker Hood, Xenon Front/Saleen Rear Bumpers, Bullitt Side Scoops, 18"FR500 Wheels, CDC Bar And Much More!
Threads Similar to: HELP White Face Gauge Install!
white face gauge question red2k2gt 99-04 18 March 9th, 2008 08:02 AM
white face gauge help plz! Tmac3320 Audio/Video 4 January 5th, 2008 09:20 PM
White Face Gauge Install Silver6 99-04 7 December 7th, 2007 03:52 PM
White face gauge install energiesource 99-04 9 July 25th, 2007 02:59 PM
White Face Gauge Install jerb43 Audio/Video 3 October 19th, 2006 04:31 PM
