Help! RPM's Out Of Control
I have an '89 GT. The last couple of months my rpms have been erratic. Replaced throttle sensor and idle air control. Now when driving or sitting it still rev's to 2500rpm and can't get it to stop. I punch it,turn the car off nothing works. Any other suggestions?
11.47@120.58
Have you tried resetting the ECU (aka unhooking the battery for a few mintutes) to see if that helped? Are you getting a check engine light, if so what code(s)?
I did not unhook the battery, and no none of mine idiot lights come on. But i will try the battery. Going later to get a map sensor for it if this does not work. Thanks
if you have a aftermarket air filter some of the oil may have flown into the mass air flow sensor ----- by a bigger one and upgrade your injectors
2001MustangGTCoupeYelloww/SatinBlack*3.73Gears AuburnLSDBBKColdAirIntakeBBKCaster/CamberPlates EibachMACCatbackMACO/RHpipeSportlineSprings SteedaTimingAdjusterSteedaUpperADJ.ControlArms SteedaShocksSteedaShortThrowShifter SuperiorAxles |
#5 | |
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
I replaced alot of the inexpensive electical. Seemed to help. I do have stock intake and we tightened the bolts and seemed to help alot,trying to find the lower for edelbrock performer. Did trade with someone for the upper and probably won't see money or intake. I do have upgraded injectors though.
Threads Similar to: Help! RPM's Out Of Control
| RPM's not decreasing when off gas | smokiebear911 | 99-04 | 8 | March 1st, 2007 10:31 PM |
| Vibration at 2500 RPM's and greater | Steves LX | 5.0 Mustangs | 7 | February 20th, 2007 07:49 AM |
| 95 GT rpm's fluctuates at idle | Muchavio | 94-95 | 1 | February 8th, 2007 10:49 PM |
| RPM's & Springs | fhinesley | 99-04 | 4 | January 28th, 2007 07:24 PM |
| Code P1443 Evaporative Emmision Control System Control Valve | jagstang96 | 96-98 | 10 | September 5th, 2006 07:26 PM |
