broken valve???
Old April 21st, 2008, 11:04 PM   #1
shortskirtsnturbos is on a distinguished road
broken valve???
My car started to idle very rough and there is a flutter in the exhaust. So i pulled all of the plugs and found one that was smashed. I did a compression check and there is 90 lbs. of pressure. What do u guys think happened? I have an 01 mustang bullitt with 60000 miles on it. Any help is appreciated.
Old April 24th, 2008, 11:28 AM   #2
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
The only way i can think of smashing a valve is the piston hitting it... On a bone stock engine this shouldn't happen... But if your valve is smashed you would have noticed it the very instant it happened as it would do damage to a piston and you'd hear them when they collide...
I can't tell you exactly what happened... Id you have some pics i could give you a pretty good idea though.
Old April 29th, 2008, 05:04 PM   #3
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
plug could have broke. fellinto the cylinder then tried to exit thru the exhaust valve causing it to break the valve...any smoke coming out the back?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Threads Similar to: broken valve???
Broken 360 DarkSidejoker The Clubhouse 7 February 18th, 2008 11:11 AM
Broken Valve cover bolt kinghack 2005 - 2010 6 February 21st, 2007 05:45 PM
Car Broken into GreenFaleen V6 Mustangs 35 January 15th, 2007 02:28 PM
Car Got Broken Into. Help! White2000GT 99-04 9 September 6th, 2006 03:44 PM
Broken Bleeder valve cobralini 5.0 Mustangs 4 May 13th, 2006 03:33 PM
