Discussing Gay Hood in the Modular Mustangs Forum. So the hood scoop looks badass yes. Buttt the fact that it is none functional ...
Old October 24th, 2006, 06:47 PM   #1
Gtwrestler's Avatar
Gay Hood
So the hood scoop looks badass yes. Buttt the fact that it is none functional really pisses me off. And today i was lookin at my buddys Trans am and i saw how the cold air intake is hooked into the ram air.. Are there any stang hoods that have cold air intake that hook up to the scoop? Or are there even any stang scoop hoods that are functional??
Old October 24th, 2006, 08:18 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
$800 - http://www.classicdesignconcepts.com...splay/561.html
there are other ram air style aftermarket hoods;
http://froogle.google.com/froogle?q=...en&btnG=Search
...even fire and single cammin
Old October 24th, 2006, 11:09 PM   #3
Gtwrestler's Avatar
thanks man. Any idea how much hp The shaker hood intake adds? same as regular intake more less? Was looking for it on the page but didnt see any stats
Old October 25th, 2006, 01:33 AM   #4
The Cable Guy...
ChrisJ's Avatar
SLOW
I dont knwo that it adds anything...It might add a few poneys but I dont know to tell you for certain...
I know Stormin Noramn hoods are made to be used like that...But I think they only make fox body hoods and set-ups...
My Junk
www.myspace.com/cjobe
Old October 25th, 2006, 05:01 PM   #5
Gtwrestler's Avatar
its gotta add soemthin... it says its cold air intake and sence its a more direct shot to the engine then in the wheel well and has a larger intake i would assume it would add a decent amount.. im not sure though
http://www.myspace.com/the_boon
Old October 25th, 2006, 06:35 PM   #6
drgnracin72's Avatar
2000 mustang GT
11.79@125
dude, a cia does not make a lot of power unless youve got huge heads, cams and headers and need to get the colder air. people say they "feel" the difference when they put a cia on but its all in their mind. it might do 3-4 hp and your not gonna really notice 3-4 hp
if i had a cobra R, i'd take out the vents and put little miniature fish tanks in their places and fill them with sea monkeys
Old October 25th, 2006, 07:12 PM   #7
Gtwrestler's Avatar
Then whats the point in haveing a mach 1 over a gt? im not sure of a difference in the two besides the shaker hood and then some other little foo foo things i.e. body kit floor matts etc? is a mach 1 pushin mroe horses or is the difference mainly in apperence?
p.s. drgnracin72 i saw your burnout clip nice run.
Old October 26th, 2006, 08:58 AM   #8
the mach 1 is a dohc where the gt is sohc personally if i could afford it o with the mach 1better staut hey thats just me
Old October 26th, 2006, 11:17 AM   #9
2000 mustang GT
11.79@125
are ya kiddin me with the mach 1 deal. its a completely different motor, thats why its makinf a lot more power. the mach has the 4v heads and the gt has 2v heads, huge difference in air flow. thats why it makes a shit ton more power thn the gt. and thanx for the props on the burnout
Old October 26th, 2006, 06:21 PM   #10
Gtwrestler's Avatar
gottcha i was wondering i know jack shit about mach 1's thanks for the info though ill hold off on that hood then thought they would add alot more then reg cai because its direct to the engine. guess i was wrong though ill go with 4v heads after gears? or would yall sugject another kidna heads?(i have no idea whats available head wise.) ive decided id like to reach around 350rwhp or so without turboing or supering.. is this possible to do and keep my stang a daily driver?
Old October 26th, 2006, 09:13 PM   #11
2000 mustang GT
11.79@125
not without nitrous. its possible to ge tthe 2v to that n/a but your not gonna wanna drive it every day. its gonna take huge heads and radical cams. your best bet is to just slap a s/c on there. its cheaper to!!! you probably dont wanna swap in 4v heads either cuz its a PITA and youd have to have a couple holes drilled on your block for timing stuff. the 4v swap is usaully best don with the whole cobra or mach motor. makes it a ton easier. your best bet for making that kind of power is either a super charger or nitrous
Old October 26th, 2006, 11:53 PM   #12
Gtwrestler's Avatar
welll i guess ill start saven for s/c or t/c then i dont wana go nitris i hear alot of 4.6's with nitris dont take well and if u have one bad part in ur engine the nitris will work on it. soo what should i go for after gears?? just start saven for some sort of charge? or would it be worth while to go after somthin else first?
Old October 27th, 2006, 07:36 AM   #13
2000 mustang GT
11.79@125
i say od you gears, then an exhaust and then do your blower. ntrous isnt going to hurt your motos un;less you dont tune for it. you have to tune for it for it to be safe. as long as you keep the n2o levels to a sane level you could run it on your motor for a long time. i say do your gears, full ehxhuast and then do a supercahrger. dont spend the money for a turbi cz youll never be able tot ake advantage of it!!!
Old October 27th, 2006, 09:11 PM   #14
Gtwrestler's Avatar
well ive already got exaust and cai so i guess gears and then super? i dunno though im hearin theres chips out there that will add like 30hp for like $340?
Old October 28th, 2006, 03:34 AM   #15
The Cable Guy...
ChrisJ's Avatar
SLOW
Those chips are bogus...
Get some gears and then go for a blower...Get a good tune and you will be happy...
Full exhaust to me is headers as well...
My Junk
Old October 28th, 2006, 10:29 AM   #16
Gtwrestler's Avatar
Hm alrighty. I wasnt aware you needed to tune without some sort of t/c or s/c ?
Old October 28th, 2006, 10:56 AM   #17
Any mustang could use a tune just for more power
Old October 28th, 2006, 10:56 AM   #18
The Cable Guy...
ChrisJ's Avatar
SLOW
I was talking about after the supercharger...
My Junk
Threads Similar to: Gay Hood
GT Hood Scoop on stock v6 hood. JSapit Visual 4 July 13th, 2007 01:57 AM
Hood Scoop for 99-04 Gt Factory Hood Black if possible Bigb2000GT Want to Buy 0 June 9th, 2007 11:07 AM
where can i get this hood and hood scoop thecloneranger Visual 4 May 14th, 2007 12:29 PM
GT Hood on 6er Cmpfreak88 Visual 12 March 7th, 2007 01:56 PM
Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. Chris02 99-04 16 November 1st, 2006 08:46 AM
