pushrod vs dohc or sohc
LinkBack (1) Thread Tools
Old May 7th, 2008, 11:15 PM   #1
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
what is the difference between the push rod(i think the vette zo6 has them) and the dohc/sohc(our cars)
MAD Stangs #8
Old May 7th, 2008, 11:55 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
entirely different engine design.
Pushrod has a single cam in the block.
SOHC has a single cam in each of the cylinder heads.
DOHC has two cams in each of the cylinders (one for intake, one for exhaust).
O o
/¯/______________________
\_\
Old May 8th, 2008, 12:01 AM   #3
In terms of performance, pushrod motors are usually torquier, and OHC designs will rev higher and be more hp oriented.
OHC designs are usually more efficient.
O o
\_\
Old May 8th, 2008, 12:01 AM   #4
Admanistrator
v606er's Avatar
o. i assume the pushrod is better cause the z06 is faster... but which one is actually better?
EDIT: ok well that answers my question. i guess we posted at the same time
MAD Stangs #8
Old May 8th, 2008, 12:36 AM   #5
Chassis aside, the Z06 is fast for two reasons:
1) The LS-series are the most efficient pushrod motors ever made.
2) The LS7 is 7 liters... as in 427 cubic inches.
O o
\_\
Old May 8th, 2008, 12:57 AM   #6
1998 Mustang GT
Need to hit the track
RandoGT is on a distinguished road
with that said, (hypothetically speaking of course) if Ford was to take their 4.6 and say "hey, let's make it a 7 liter", use the same technology as the LS7, same grind cam, head ports alike, everything...which one would make more power?
2nd option. if the 4.6 was to be upped to a 5.7 (to match the LS1), leaving it as is, how would they match up powerwise?
Old May 8th, 2008, 09:43 AM   #7
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Ford already has (had?) a 7 liter pushrod engine. It was the 428 Cobra Jet and they used to put them in Mustangs. They changed to the modular motor for a more efficient manufacturing process.
If you want a 5.8 modular motor, MMR has the block for you. Scroll down about half way.
Modular Mustang Racing
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old May 8th, 2008, 11:55 PM   #8
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
just FYI... ALL GM trucks and SUV's between 1999 and NOW all have LS series engines. i have a 4.8 in my truck which see's 7000+ rpm every weekend... stock motor, just upgraded vlaves springs... 20 minute chore.
in all fairness, if built correctly (actually balanced... or at least halfway...)most any OHV V8 motor will spin just as well as any OHC V8 motor.
i like to think about like this: every GM vehicle with 5.3 to a 6.0 ls v8...
all you need is a cam/spring swap, good exhaust (as in NO manifolds or shitties) and tune and 100 extra hp can be had.... out of any LS... with any miles... 6 bolt mains, cathedral cylinder heads, stock internals can withstand upwards of 700 hp and 20+# of boost.................................... hows that for some chevy knowledge...
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old May 9th, 2008, 12:01 AM   #9
qwik48r's Avatar
alotta shit
no fat girls fast
and ford actually had a 427... called it a side oiler. put it in the cobra... actually ford came out with the 427 first... a original 427 Sideoiler block is worth about 5 grand now in good condition... have a buddy thats got an original sitting in his shop right now... its got a busted main bearing valley... once he gets that welded... its going in a factory five for some lucky bastard....
qwik's build
Old May 9th, 2008, 12:10 AM   #10
Admanistrator
v606er's Avatar
they are selling roush 427s where i am
MAD Stangs #8
Old May 9th, 2008, 12:18 AM   #11
qwik48r's Avatar
alotta shit
no fat girls fast
yea they arent 427 CUI motors.. just 427 hp..
i m talking about the 427 s.o made in the 60's (started in 64' with the cobra.. after the 289 lol)... then chevy decided to make a 427 and put it in the vette
qwik's build
Old May 9th, 2008, 12:31 AM   #12
Yeah, those aren't named for their displacement.
Ford also had a SOHC 427 or 428 (I forget which) back in the 60s that was going to be used as a NASCAR motor.
If you were to take a current 3v 4.6L and scale it up to a 7.0L, assuming no efficiency gained or lost, it would make ~466 hp. Scaled up to a 5.7L it would make ~372 hp.
OHC designs are more optimal for rpm due to the reduced oscillating mass. You're not fighting the extra intertia of the pushrods & lifters to actuate your valves. I've also yet to see an OHV motor with more than 2 valves per cylinder (if my memory serves, 5v motors are mathematically the most efficient design you can have - which is why Ferraris use 5v motors, as did the top-end Toyota 4A-GE).
If you think that a OHV motor can rev, compare the most advanced pushrod motors in the world (NASCAR engines) with the most advanced OHC engines (Formula 1). Nascar motors turn 10-11k rpm (if I recall correctly, please correct me if this is wrong). F1 motors turn 17-19k.
OHV motors do have their advantages, too. Their compact heads allow a much larger displacement motor to occupy the same amount of space: a DOHC 4.6L is the same size externally as a 429 or 460. This means you can have a LOT more torque in a smaller package, and keep the rpms down (which in turn leads to motor longevity).
O o
\_\
Old May 9th, 2008, 12:35 AM   #13
Admanistrator
v606er's Avatar
i heard about that engine ford made that was supposed to be for nascar, but it was too good or something
MAD Stangs #8
Old May 9th, 2008, 12:38 AM   #14
Admanistrator
v606er's Avatar
why the push rod if ohc's are better(thats what i got out of your last post), then why is there the pushrod?
MAD Stangs #8
Old May 9th, 2008, 12:43 AM   #15
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
The OHC heads aren't that compact. A 4v 4.6 is alot wider than a big block. If you compare a cobra motor next to a LS-7 the ls motor will look like a baby and it is mostly the heads. As for power to size. a 5.0 cammer (dohc 5.0 modular from FRPP) is over 400hp and thats with about 302ci. The power in the OHC motors is in the heads. The 2v's can make torque to compare with a pushrod motor but the 4v's make the HP but need to rev high to do it. GM has a great motor in the LS and the mod motor is a love or hate thing. There is alot of power to be had in them but the cost can be high. You can make 450whp with a 4v with alot less cubes than the LS has.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old May 9th, 2008, 12:45 AM   #16
Admanistrator
v606er's Avatar
i am really confused. what do the 2v or 4v mean? is that v6 and v8?
MAD Stangs #8
Old May 9th, 2008, 12:48 AM   #17
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
2v head or 4v head.
Military Crew
U.S. Army Aviation
Old May 9th, 2008, 12:51 AM   #18
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
4v head. Like on the cobra and Mach motors. 4 valves per cylinder
2v head like on the Mustang GT's. 2 valves per cylinder
Military Crew
U.S. Army Aviation
Old May 9th, 2008, 12:57 AM   #19
qwik48r's Avatar
alotta shit
no fat girls fast
its funny NASCAR small block makes about the same power as an F1 motor at half the rpms.... OHV's make there magic, in their heads
that was the 427 cammer your talking about
the less inertial mass is why they make more power up high... again OHV makes power in the head and chamber design correlating perfectly with the cam profile. OHC with less inertial mass, is ACTUALLY able to twist to 19K+, taking advantage of a different type of cam profile.. OHC motor generally can accomodate a more aggresive grind while still being tame...
we have a 383 here in the shop... actaully used to be a 2 bolt main we retrofitted after it flung a slug... got a set of Racer Pro's from Australia (cheap good head) and a monster bumpstick... we dual step it.. 5000 and th400 redline is set at around 10,000rpms
qwik's build
Old May 9th, 2008, 01:10 AM   #20
Pushrods are an earlier design, easier to work on, cheaper to modify. And pushrods are pretty rare anymore when you look at cars on a global scale. American companies are the only ones that still sell a pushrod motor, and even then it's only GM and Chrysler.
If you give Joe America the choice between a 427 and a Turbo 3.8L, he'll take the 427 almost every time, even if the Turbo 3.8L makes more torque, more hp, and gets double the fuel economy.
O o
\_\
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/69995-pushrod-vs-dohc-sohc.html
4 cam modular in gen 1 - Page 3 - The National Lightning Owners Club Inc This thread Refback January 1st, 2011 01:57 AM
Threads Similar to: pushrod vs dohc or sohc
sohc to dohc usmc513 96-98 3 October 30th, 2007 04:59 PM
sohc to a dohc? gtdan 96-98 11 September 6th, 2007 01:53 AM
SOHC to DOHC energiesource 99-04 9 May 16th, 2007 10:06 AM
SOHC to DOHC NMR-2vGT 96-98 6 March 13th, 2007 10:51 AM
SOHC 4.6 to DOHC 4.6 rattlesnake28977 Modular Mustangs 8 December 6th, 2006 02:16 AM
