Discussing 1999 SVT Overheating Problems in the Modular Mustangs Forum. I have been working on a 1999 cobra for a couple weeks already trying to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1999 SVT Overheating Problemsit started out one day just got it out driving a while and notice the gauge going up stop the car was missing fluid put it in bleed the systems and still does it I change the thermostaat didn,t help change the temp sensor ,change radiator cap ,change waterpump still didnt help it does it only while driving standing idling stays good so a change both head gaskets hell of a job both gasket samed fine check the heads look fine also I by pass the heater and put everything back to getter started up left it idling stayed good went to drive it it starts heating again but after running it 10-15 min does the same any ideas I am out of them !!
AssHole Admin
2000 mustang GT
11.79@125
your gauge could be screwed?
Maintenance Man
11.47@120.58
Is it still losing anti-freeze? If it's not leaking it then it's burning it. Have a pressure test done on the cooling system.
#4 | |
Haha, ever think of pressure testing the system. Im suprised you havent done that already. Also could use head gasket detector tool, not sure what the exact name is but you put it in the overflow and squeeze it once the motor is warmed up and it turns colors.
Also: Tsb for heater core. The 2 valve motors had more problems with headgaskets, but its still not out of the question. I would pressure test it first. If youre loosing fluid and it doesnt show up, then yeah headgaskets may be leaking. Good luck
White99stang-
93 LX, H/C/I + Vortech |
well I will try presure testing this weekend
but yes when the gauge goes up it start trowing water out of the reservoir tank |
Have you checked the fan? I had a similar problem... The car would begin to heat up after about 15 minutes of driving, so I installed a manual fan switch to the ECU. When I first got in the car and turned on the switch, the fan came on just fine. After driving for 10-15 minutes, the car started to heat up, so I pulled over and the fan was off. Just got a new fan 2 days ago and have no more issues. Good Luck!!
2002 GT- 6spd, Forged block, vortech t-trim, paxton intercooler, 60# injectors, Aeromotive Fuel System, KB Boost a Pump, Spec Stage 3 Clutch, 90mm SCT, long tubes, bbk o/r x-pipe, bassani cat back, Steeda Suspension 471.3@6100 / 435@4850 (b4 fuel system) |
#7 | ||
White99stang-
Yes water overflows water out of the tank
#9 | |
Ok, this clears up alot then. I thought you meant it was disappearing as in headgaskets. I would skip the pressure test then and deff. check to make sure the fans are working. Just turn on the a/c and the fans will turn on automaticly. If not you have fan problems.
White99stang-
thx guys I think I found the problem
I took the radiator out and send it to the radiator place the called me up told me the radiator was pluged !!!! I didn,t think about that before cause coolant every thing same clean no dirt I will get it back this afternoon and try it out |
get a alummium radiator and i would check the fan to casper said , and by the way you live in aruba i love it down there
![]() 2000 ford mustang gt convertible 2004 ford lightning truck 2001 ford mustang/cobra 2008 ford f-350 4x4 truck |
#12 | |
Yeah and if anyone knows why please tell me. but it seems every 4.6 no matter DOHC or SOHC always seem to have a huge build up of white pasty looking stuff in it.
White99stang-
i have never seen that in mine but i will keep a eye on it
Threads Similar to: 1999 SVT Overheating Problems
| 4.6 DOHC overheating problems | Moffatt | 99-04 | 4 | April 2nd, 2007 07:34 PM |
| 1999 mustang electric problems?? | ronsmith13 | Electronics | 5 | March 26th, 2007 11:45 PM |
| 96 Overheating | 6 banger stang | V6 Mustangs | 2 | October 30th, 2006 01:58 AM |
| Mustang overheating problems | Devildog | General Tech | 6 | August 2nd, 2006 07:54 PM |
| Overheating | 90Stang | 5.0 Mustangs | 19 | July 31st, 2006 05:30 PM |
