Timing problem, piston/valve clearance?
Old May 19th, 2008, 11:39 AM   #1
Yella01Stang's Avatar
Yella01Stang is on a distinguished road
I have a 10cc butterfly dish piston and stock pi heads. I know how to time my 01 SOHC 4.6 but for some reason with the timing maks all lined up and the crank in the correct position and the cams in the correct position they still hit. Every mechanic I talk to says it shouldnt hit and has no answer for me...has anyone had this problem?
2001 GT Stang
"Bullitt #5583 wanna-be"
Best ET 13.8 104mph (b4 motor/gear)
D.S.S. ProMod ShrotBlock, DiabloSport Predator,
Steeda TriAX, FRPP 4.10s & D-shaft, FRPP 24# injct,
Flowmasters, 03 Cobra Brakes, one awesome
tune & much more ;]
Old May 28th, 2008, 12:33 AM   #2
tom2000r is on a distinguished road
I have,,it was on intakes..
Old June 1st, 2008, 02:30 PM   #3
Thanks...how did you fix it, replace the valves?
2001 GT Stang
tune & much more ;]
Threads Similar to: Timing problem, piston/valve clearance?
Piston Clearance 95StangMX 5.0 Mustangs 11 January 10th, 2008 10:51 AM
Piston to valve clearance. IcantDo55 5.0 Mustangs 2 December 30th, 2007 01:04 PM
Piston to Valve Clearance 94GTD1SC 5.0 Mustangs 6 April 11th, 2007 03:39 PM
Help With Piston to Valve Clearance 1WLDSTANG Classic Mustangs 2 November 12th, 2006 06:11 PM
PISTON TO VALVE CLEARANCE FUNDAMENTALS 173speed 5.0 Mustangs 0 October 7th, 2005 09:47 PM
