difference between rai and cai
Old May 30th, 2008, 12:16 AM   #1
Admanistrator
v606er's Avatar
v606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud ofv606er has much to be proud of
please explain the difference between the rai and cai
MAD Stangs #8
Old May 30th, 2008, 11:14 AM   #2
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
a cold air intake places the filter in a more remote location allowing it to suck colder air... away from the heat of the engine. a ram air intake is basically just a piece of pipe and a filter coming out of your intake. they are pretty useless IMO. even though rai's are cheaper, it's def. worth it to get the cai.
Old May 30th, 2008, 11:22 AM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
rai
cai
Old May 30th, 2008, 11:33 PM   #4
Admanistrator
v606er's Avatar
Originally Posted by HMUSN View Post
rai
cai
o wow. i guess all the things ive seen are rai's. b/c they all have the filter visible in the engine compartment. but they also have a little heat shield or something around them. how will i know the difference between cai and rai when i ordewr it so i dont get nailed in the ass by someone?
MAD Stangs #8
Old May 31st, 2008, 09:19 AM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
it will say either ram air or cai/ fender well
shoot me a pm with a link before you buy it and I will confirm it for ya
Old June 1st, 2008, 12:09 AM   #6
Admanistrator
v606er's Avatar
ok thanks
MAD Stangs #8
Old June 7th, 2008, 05:23 PM   #7
2007 V6 Pony
thirblig is on a distinguished road
I didn't catch this thread right away so you may have it all figured out by now but just in case you don't ...
CAI = Cold Air Induction - air is drawn into the engine from an area isolated from the rest of the engine compartment. Those filters you see with the shield around them are CAI systems. The shield reduces the amount of hot air getting to the filter so that cooler air can be drawn in from outside via the space behind the fender. They work with about the same efficiency if the car is moving or standing still.
RAI = Ram Air Induction - outside air is forced into the engine but the vehicle must be moving for this to happen. I'm not sure at which speeds they generally become effective. Ram air systems will usually utilize a functional hood scoop which seals to the intake system when the hood is closed OR they can use ducting to draw air from the front of the car. I've never had one but anything that will force more cool air into your engine is going to add to your power output.
Hope this helps.
2007 Grabber Orange V6 5 spd w/ Hurst Shifter, 4" aluminum driveshaft, 8.8" rear end w/ trac-loc, XCharger #64
Old June 7th, 2008, 06:16 PM   #8
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
The RAIs work well at the track with the passenger headlamp removed.
TT Build in progress.......
Threads Similar to: difference between rai and cai
CAI vs RAI HBK_2007 96-98 2 May 4th, 2008 01:40 PM
JLT RAI or CAI? andres0286 99-04 8 April 29th, 2008 11:23 AM
RAI OneBoredGuy 4V / SVT 21 February 13th, 2008 09:18 PM
CAI or RAI Mach Boy 99-04 21 October 12th, 2007 12:13 PM
CAI or RAI? 4point6GT 96-98 3 June 25th, 2006 09:40 PM
