Gears - FRPP vs Motive - Just a Little Clear Up
LinkBack (1) Thread Tools
Old June 12th, 2008, 05:33 PM   1 links from elsewhere to this Post. Click to view. #1
DiZzyBonne's Avatar
2001 Ford Mustang Bullitt
DiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the rough
Send a message via AIM to DiZzyBonne
Everybody seems to think that Motive makes Ford's gears. This WAS true about a year ago. If you're buying gears, and the part number ends with an N, such as M-4209-F373N, then you're fine. I just got the answer from Mike at FRPP directly. He said Motive stopped making their gears about a year ago. He also said that the ONLY gear that was made by Motive that had the problem were the 3.55s. All other gears were fine, but Ford started making their own gears once again anyway. I hope this clears up a lot of confusion between Ford, Motive, and who makes what. So make sure you see that N at the end of the part before buying them if you REALLY want original Ford! Besides, the N also means it's made with a new process.
Originally Posted by http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=5701
New manufacturing technology utilizing a Face Hob Process which features a single pass pinion tooth machining operation compared to a conventional three pass process for machining. CNC cut and lapped gear teeth. Higher strength and better quality gears are produced with the Face Hob Process. NOTE: These new gears look a little different, the gear teeth are cut on a different angle and the ring gear has a bevel on the back of the gear.
Current mods:
  • Maximum Motorsports XL Full Length Subframe Connectors
  • Catted Bassani X-Pipe
  • Borla Stinger Catbacks
  • H&R Super Sport Springs
MM Bullitt Crew Founder and Member #1
Old June 12th, 2008, 05:45 PM   #2
562cobra's Avatar
2003 Mustang Cobra
562cobra is on a distinguished road
this helps alot as i am going with some 4.10s frpp.
MM Cobra Club Member #28
Old June 12th, 2008, 08:15 PM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Good info. And good job digging up the facts man.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old June 12th, 2008, 08:18 PM   #4
yojoe600's Avatar
yojoe600 will become famous soon enough
thanks this will help when im buying gears
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/75552-gears-frpp-vs-motive-just-little-clear-up.html
Gears - FRPP vs Motive - Just a Little Clear Up This thread Refback June 13th, 2008 12:47 AM
Threads Similar to: Gears - FRPP vs Motive - Just a Little Clear Up
Gears: frpp 3.73 or Motive 3.90? eLLuSioNiST 2005 - 2010 9 May 20th, 2008 09:23 PM
Motive VS. FRPP sstang 99-04 10 October 25th, 2007 02:38 AM
How can you tell the differents from Motive an FRPP gears. Kennhyy3 V6 Mustangs 4 April 27th, 2007 04:07 PM
FRPP 3.73 gears with Motive Complete Installation Kit? Blue98GT Modular Mustangs 2 January 16th, 2007 11:01 PM
Motive Gears Vs. FRPP themav46 V6 Mustangs 6 January 9th, 2007 09:58 AM
