LinkBack (1) | Thread Tools |
#1
48.47@ 12.58
4.6 Torque specs
4.6L Torque Specifications*
(ft-lbs unless otherwise indicated) Camshaft sprocket bolts......................... .............82 to 95 Camshaft caps to cylinder head.......................... .71 to 106 in-lbs Timing chain cover bolts .............................. .......15 to 22 Drive belt idler and tensioner bolts......................15 to 22 Cylinder head bolts 4.6L-SOHC Step 1............................. .............................2 8 to 31 Step 2............................. .............................T ighten an additional 90-degrees Step 3............................. .............................L oosen one turn Step 4............................. .............................2 8 to 31 Step 5............................. .............................T ighten an additional 90-degrees Step 6............................. .............................T ighten an additional 90-degrees 4.6L-DOHC Step 1............................. .............................2 8 to 31 Step 2............................. .............................T ighten an additional 90-degrees Step 3............................. .............................T ighten an additional 90-degrees Vibration damper-to-crankshaft bolt 1996 .............................. .............................. ...114 to 121 1997 and later Step 1............................. .............................6 6 Step 2............................. .............................L oosen one full turn Step 3............................. .............................3 6 Step 4............................. .............................T ighten an additional 90-degrees Valve cover bolts .............................. ...................71 to 106 in-lbs Oil pan-to-engine block bolts 1996 .............................. .............................. ...15 to 22 1997 and later Step 1............................. .............................1 5 Step 2............................. .............................T ighten an additional 60-degrees Exhaust manifold-to-cylinder head nuts ..............14 to 16 Intake manifold -to-cylinder head bolts 4.6L-SOHC.......................... ............................15 to 22* 4.6L-DOHC Upper plenum to intake........................ .......71 to 106 in-lbs Intake to lower side plates (2 small bolts) ..71 to 106 in-lbs Intake/side plates assembly to cylinder head Step 1 .............................. ........................15 to 22 Step 2 .............................. ........................Tighte n an additional 90-degrees Oil filter adapter bolts .............................. ............15 to 22 Oil cooler-to-filter adapter insert 1996 .............................. .............................. ...59 to 74 1997 and later .............................. ..................41 to 53 Oil pump-to-engine block mounting bolts ...........71 to 106 in-lbs Oil pick-up tube-to-main bearing cap nut ............15 to 22 Oil pick-up tube-to-oll pump bolts.......................71 to 106 in-lbs Flywheel/driveplate mounting bolts .....................59 to 64 Ignition coil brackets to front cover.....................15 to 22 Timing chain tensioners/guides ..........................15 to 22 Engine mount-to-engine block bolts/studs..........25 to 33 Engine mount stud to crossmember nuts ...........95 to 126 Engine compartment brace bolts......................... 15 to 22 Wheel lug nuts.......................... ...........................85 to 105 Firing order......................... .............................. ...1-3-7-2-6-5-4-8 *After assembly, retorque with the engine hot.
2011 Mustang GT
12.1 @ 116
straight out of the haynes manual. I know this page lol.
Thanks HMUSN for now making it just a click instead of fumbling through the pages
Mods in garage. Built suspension and gears since posted times. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/75928-4-6-torque-specs.html
| 4.6 Torque specs | This thread | Refback | June 15th, 2008 10:20 PM | |
Threads Similar to: 4.6 Torque specs
| 4.6 Torque Specs | Twist 2 Go | Modular Mustangs | 29 | June 21st, 2010 12:32 AM |
| torque specs please | 96gtstang&V6 | V6 Mustangs | 3 | May 16th, 2008 05:29 PM |
| torque specs | 1 SNAKE 3 | V6 Mustangs | 4 | January 24th, 2008 11:06 PM |
| Torque Specs | street591 | V6 Mustangs | 13 | January 10th, 2008 05:48 PM |
| Torque specs | G.T. Rags | 5.0 Mustangs | 13 | August 11th, 2007 10:47 PM |
