2006 Mustang 4.0
![]() iTrader: 1 reviews
Stroke 5.0
so the gt has 260 hp right? how much would it make if i stroked it or whatever to a 5.0. Also does that mean forged internals? or is it just a block. I'm not to engine smart lol.
Also same question with a mach 1 |
there is A LOT of mathamatical equations to figure out how to get a 4.6l to a 5.0l......but a liter in a motor is the displacement of each cylinder.....but if you want to make a 4.6 to a 5.0 you could bore your cylinders .030 over and put a stroker kit in it that might give you a bigger displacement than you want if you want it to be bigger...but if you want to get it on the spot you got to go through a lot of mathamatical equations
#5 | |
ok.....http://www.moranav6racing.com/catego...?CategoryID=16 makes a 4.4 stroker kit for the 3.8.....ok so now you need only .6 more liters...how would you do that bore your cylinders :wink
well there are a couple differetn ways to go about getting the 4.6 to a 5.0 you can do it with a stock bore of 3.552" or .020 bore which is 3.572, a forged cobra crankshaft, that uses a 3.75 inch stroke. youll need to get the propper rods which are usualy a 4340 h beam rod and the right pistons. the pistons are different becuse the bottom ringland will intersect the wrist pin and it will pull the piston a little bit further out of the block. there is not a problem with doing this. some people will say that its bad but that isnt the case.
just put a blower or turbo on it lol
no stroke it first and then put a blower on it
2006 Mustang 4.0
sorry i have been gone for the weekend but i just wanted a guesstimate lol on the rwhp or just base hp if you made a 4.6 a 5.0
thanks |
well i have a stroker modular with stage 2 heads and cams, and low compression so without boost its not gonna be a lot. but it made over 300 rwho and if it was optimised for n/a i bet it could have made upwards of 350 rwhp all while being n/a
Threads Similar to: Stroke 5.0
| 2v to 4v conversion and a 281 to 302 stroke.. | MustangDrew212 | Modular Mustangs | 3 | August 20th, 2007 10:37 AM |
| Stroke it baby..... | Ole Yeller | V6 Mustangs | 20 | July 7th, 2007 07:56 AM |
| Stroke...huh? | marcfiebka | 99-04 | 2 | April 27th, 2007 03:38 AM |
| to stroke or not to stroke | Rantheman | 96-98 | 19 | July 5th, 2006 01:36 PM |
| To stroke or not to stroke | Vamp89 | 5.0 Mustangs | 4 | May 9th, 2006 01:19 AM |
