Tach install Quick question please!!
Ok guys I need a little help.
I just installed a sunpro tach ( cp2012) I took the signal off my ecu. Same place as my raptor shift light & my msd window switch. But the tach won't rise above 800rpms Do I have to have a tach adaptor? And if so Why? Please reply Troy |
MM's nicest mod, :)
do you have a digital window switch
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
MM's nicest mod, :)
oh now that i think about it you will need a tach adapter, the signal the tach needs is a 12v square wave pulse and the signal coming from that wire is a sine wave. The raptor shift light works there cause it is programed to read the sine wave and same with the window switch.
MM's nicest mod, :)
so in instance you are only reading off one coil right now. thats why if you multiply the max rpms the tach will go by 8 then it would read normal lol
#5 | |
MM's nicest mod, :)
your still gonna need a tach adapter cause the window switch is programed to read off one coil also. you can find them for around 40 bucks used
#7 | |
I'll start looking. Do you have an extra one in your pocket
MM's nicest mod, :)
nope just the one already on the car
Oh cool that one will work
I'll stop down later and pull it out of your car.Thanks Troy |
Threads Similar to: Tach install Quick question please!!
| anyone ever install a tach on a 99-04 v6? PLEASE HELP! | ricerraper33 | Audio/Video | 8 | September 20th, 2007 10:35 PM |
| Tach mount in 72 dash question | Mach1460 | Classic Mustangs | 1 | March 11th, 2007 04:00 PM |
| I have a question on installing a tach | ocsailor86 | 96-98 | 3 | February 14th, 2007 04:07 AM |
| Question About Inop Tach 93 Foxbody | ret27m | 5.0 Mustangs | 2 | November 9th, 2006 12:41 PM |
| sun pro tach install | terribleonexx88 | 5.0 Mustangs | 1 | October 19th, 2006 02:18 PM |
