Modifications for installing Canton windage tray
LinkBack (1) Thread Tools
Old July 24th, 2008, 05:51 AM   1 links from elsewhere to this Post. Click to view. #1
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
When we went to install the windage tray on the short block we found there are some clearance issues on the pan and pick up tube. Just an FYI if you are wanting to put one on this may save you a little surprise later. The first pic is of the oil pan. It shows 2 windage tabs that need to be removed for clearance, they are opposite the sump.
This pic shows how the pick up tube was modified to work with the windage tray. You can see where we torched off the bracket that is on the pick up.
This pic is of the pump and pick up just to show you the bracket we removed on the pick up tube for comparison to the previous pic.
Here is the installed pump, windage tray, and pick up.
-Matt
Military Crew
U.S. Army Aviation
Apache's Lead The Way
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/81532-modifications-installing-canton-windage-tray.html
Modifications for installing Canton windage tray This thread Refback July 25th, 2008 05:02 PM
Threads Similar to: Modifications for installing Canton windage tray
Canton windage tray mustang fanatic 2005 - 2010 7 July 14th, 2008 08:23 AM
Windage Tray poisonstallion95gt 94-95 3 November 17th, 2007 01:09 AM
Windage Tray 1stimeford 99-04 3 May 19th, 2007 04:14 AM
WTF rpmoutlet. 20mins windage tray install whtleroy4you 2005 - 2010 4 December 25th, 2006 02:15 AM
