clutch noise
Old July 31st, 2008, 02:20 PM   #1
2000 GT
N/A
thatonekidw/theGT is on a distinguished road
Send a message via AIM to thatonekidw/theGT
clutch noise
I bought my GT about 1 year ago. When I bought it. The clutch was acting weird so I ordered a King Cobra kit and had it installed. No problems until recently. Over the last few months when I start the car and the engine is cold, when I push my foot down on the clutch it makes a ringing noise or a chattering sound. It is similar to a loose exhaust hanger tapping on the pipe very quickly(but higher pitched and not as loud). At start up it does it alot but as it warms up its only when the clutch is pressed in. I am having no engagement issues though. Shifts are easy and smooth. Its just the noise right now. Any advice or input is appreciated! Thanks guys!
Old July 31st, 2008, 10:47 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
sounds like a throwout bearing
Old July 31st, 2008, 10:49 PM   #3
2000 GT
N/A
That was also replaced when the clutch was changed out. I suppose it could have been defective and gone bad but it seems doubtful.
Any other suggestions? Anyone??
Old August 3rd, 2008, 01:51 AM   #4
2000 GT
N/A
comeonnn
Old August 3rd, 2008, 06:10 PM   #5
snoel123 will become famous soon enough
Because it only occurs when cold make sure it is coming from the bellhousing area. If it is it really sounds like a release (throw-out) bearing. It could possibly be a few other things (all of which require trans removal to fix). It may be wise to remove trans and inspect before you end up putting in a new clutch again. Just my thoughts.
Old August 3rd, 2008, 06:14 PM   #6
One other thing I can think of that is kinda similar is a loose catalytic heat shield or catalyst falling apart. The welds break on the heat shields and the make a rattling type sound. Pushing on the clutch would change the harmonic frequency and possibly cause resonation (much like striking a tuning fork). To be sure it is not this take a deadblow or rubber hammer and lightly tap exhaust if you can recreate the noise you know whats wrong. Another thing could be a clearance issue with the clutch ispection cover (not very likely) but I have seen it cause weird noises once or twice.
Old August 11th, 2008, 01:55 AM   #7
2000 GT
N/A
no cats so its not that. Its a new throw out bearing so i doubt its that. Its just on start up and only when the clutch is depressed even just a little bit
Old August 11th, 2008, 01:58 AM   #8
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Hmm, that's weird. It sounds like a throwout bearing to me as well. It might be going bad.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Threads Similar to: clutch noise
clutch noise ehfrenchy21 99-04 9 July 27th, 2008 02:36 PM
Odd clutch noise StangAddiction 99-04 5 July 27th, 2008 01:55 PM
Clutch noise? notch9350 5.0 Mustangs 4 April 2nd, 2008 04:00 AM
clutch noise? captain_communism 99-04 2 September 22nd, 2007 10:11 PM
Clutch noise?? Garhfer 99-04 18 July 25th, 2007 01:06 AM
