TPS probs
Old November 20th, 2006, 10:46 PM   #1
1999 Mustang
Invictus is on a distinguished road
TPS probs
can anyone tell me precisly how to adjust my TPS? when driving at a constant rpm say 40MPH at 2800rpm all of the sudden itll jsut start driving like shit.. and also just a few days ago i was racing a stock GT but we went all the way i hit 130-140MPH redlining every shift. then when i got off of it and started breakin the car died which was pretty scary.. so i let her roll to a stop and prayed to god.. HAHA but it immediately cranked back up with no problem at all. Matty told me these were symptoms of my TPS being unadjusted since i've added the accufab TB and plenum .. he said i need a certain voltage and it easy to adjust but he didnt know the specifics.
can anyone help me out here? thanks!
Old November 20th, 2006, 11:06 PM   #2
boliver's Avatar
boliver is on a distinguished road
you can adjust the butterfly on ur tb that might help its a little allen head bolt around ur throttle linkage but it sounds like ur having an iac (idle air control) problemif its not ur tps then try and cleaning out the iac with carb cleaner then spray it with a little wd40 to prevent it from sticking
01 GT WITH A FEW MODS 8.30 IN THE 1/8 MILE ON STOCK MOTOR LOOKING FOR WAYS TO REACH 7.90 WITH ORIGINAL MOTOR
Old November 21st, 2006, 02:21 AM   #3
1999 Mustang
i'll clean the iac but i dont think that's the problem.. i think its my TPS it has to be under a certain voltage and im not sure how to adjust it or even check to see if it's correct or not? do u or does anyone know the specifics?
Old November 21st, 2006, 10:02 AM   #4
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
what is the vovtage of the TPS sensor now? it should be around .95V
Old November 21st, 2006, 05:26 PM   #5
1999 Mustang
Ok i got 5V out of one wire.. then the other 2 wires i ddint get any reading at all. All 3 of them are black so I dont know which is which! When I unplug it from my tb its the contact all the way on the left. Does this mean anything? Should i have my car running when I test it?
Thanks
p.s. i still cant get over the sexiness of ur car matrix haha
BTW: my car all of the sudden is taking a little longer to start up.. like it has to turn over a good 3 or 4 more times before it cranks.. before just a couple of days ago it wouldnt hesitate to start right up immediately is this another symptom of the TPS? i hope so..
Old November 21st, 2006, 06:36 PM   #6
what year is the car?
Old November 21st, 2006, 08:52 PM   #7
1999 Mustang
04GT motor
Old November 21st, 2006, 09:15 PM   #8
1999 Mustang
Got my good digital volt meter on it.. and this time i actually unplugged the connector from the tb and put the meter rite on the metal contacts inside the plug itself.. and still i got the same 5.0V reading and then nothing from the other 2 wires... ???
Old November 21st, 2006, 09:42 PM   #9
1999 Mustang
Ok i used a needle this time and got a better reading... aparently i wasnt probing the insulation. on the first wire i got 5.0, second wire i got .96, 3rd wire i got .018
does that mean my tps is good? the .018 kinda threw me offf
Old November 21st, 2006, 10:49 PM   #10
turn the key on, leave the plug on the TP sensor. probe the middle wire and probe one of the other 2 wires. then sweep the tps sensor and watch. if the voltage changes, you found the right second wire. with the throttle closed it should be near .95v (no more than 1.00) then sweep it to full throttle very slow and see if their is any dead spots in the reading. if so you know you need a tps
Old November 23rd, 2006, 03:12 AM   #11
1999 Mustang
alright matrix.. everything seems to be okay for the tps it was a smooth sweep all the way up to 5V ..
however AGAIN today on the interstate about 20 minutes ago actually.. (brand new granatelli coil packs installed) racin a 350z up to about 120-130MPH at least i wasnt watching the speedo but i dont think i got passed that.. but as soon as i was a pretty good ways ahead of it i let off and started puttin the breaks on.. then all of the sudden it got really hard to brake and no power steering and realized my car died... Same thing that happened when i raced just a few days before. Could it be my Governor? have you ever heard of this issue? this time i was on the interstate so i couldnt exactly roll to a stop so i cranked it back up rolling at about 80mph (i had the clutch in) and it started with no problem at all i revved up a little bit to match popped it back in to 4th and had no trouble at all we even raced a few more times from a roll and had no issue (although i didnt get it back up to those speeds)
is there a governor issue on the car that i dont know about thats killing something? ive never had this problem before but the then again ive never raced that fast
Old November 23rd, 2006, 07:15 AM   #12
hmmmm. i never heard of a problem like this. i wouldnt think the limiter would kill the motor, just cut fuel or ignition till it comes back down. have you checked to see if there e was any codes in it?
Old November 23rd, 2006, 01:34 PM   #13
1999 Mustang
last code i got out of it was P1633 Manufacurer Contrl.
Auxiliary Inputs
Auxiliary Outputs
few weeks ago i had a few cylinder misfire codes when i changed to the ZEX plugs but thats been fixed with the new granatelli coil packs
also had some o2 sensor malfunction codes and even bought a new o2 sensor but now all of the sudden im not getting that code anymore?
Old November 23rd, 2006, 06:28 PM   #14
hmmmm. i dont know. the only thing i could think of beaig wrong is the tps, maf, i dont know what else would cause the problem. did you try to clean the maf?
Old November 23rd, 2006, 07:34 PM   #15
1999 Mustang
Maf has been cleaned and i took the little screen off as well. IAC has been throughly cleaned and tps checked out fine. Hmmm
Old November 23rd, 2006, 09:17 PM   #16
wish i could help man, but im out of ideas.
Threads Similar to: TPS probs
Tranny Probs chickenbot 5.0 Mustangs 11 November 12th, 2007 01:25 AM
PC probs.. El_Cangri The Clubhouse 4 July 28th, 2007 02:27 AM
More probs alabamastanger 5.0 Mustangs 1 June 5th, 2007 06:34 PM
Probs alabamastanger 5.0 Mustangs 7 May 30th, 2007 06:30 PM
sig probs. joka187 Feedback Forum 1 May 14th, 2007 12:18 AM
