Newbie question. 98 cobra with 99 cobra tranny...Speedo fix?
Old December 2nd, 2006, 08:25 PM   #1
Look Ma! My First Post!
RoyalCars is on a distinguished road
I don't know if this has been adressed anywhere yet, but I just replaced my noisy and grinding 1998 Cobra transmission with a unit out of a 1999 Cobra. I went through hell of a time moving the rear tranny bracket and reinforcing the mounting points, but thats all done now.
PROBLEM:
Speedo sensors are completely different and my speedometer reads off the scale. I am here in hopes that someone out there has a fix!
Any help would be appreciated
Thanks!
Old December 3rd, 2006, 11:07 AM   #2
FastBack71 is on a distinguished road
maybe some kind of speed calibrator
My friends used to wonder Why i joined the air force. Now they wonder why they didn't.
Old February 13th, 2007, 01:29 AM   #3
maverick_26's Avatar
1998 mustang
maverick_26 is on a distinguished road
Were you able to get your problem fixed? I'm having the same problem with my 98 gt. It has a 99' transmission in it also. If you did get it fixed please let me know. Mines reading 150+++ in third gear at around 30mph with stock gears.
Old February 15th, 2007, 10:09 PM   #4
True2theHorse is on a distinguished road
Hope this helps, but one difference is that the 99 and up stangs use a digital reading, in other words if you have a tuner/programmer you can calibrate the speedo on the 99 and up, but pre 99 the speedo uses a small gear on the tranny which has to be changed in order to recalibrate.
My guess is that you would have to check and see how the computer on in your car reads from the tranny. It may be as simple as a tuner/programmer to get it on track, looks like worse case you will just have to change the speedo gear.
Hope this helps.
Old February 16th, 2007, 10:11 AM   #5
Casper98GT's Avatar
Well the problem is the 99 trans are electr. speedos and the 98 cobra is not, it uses a speedo gear. Im not really sure what you could do. i would say get the cluster out of it but there are more harness' for the new cluster and nothing would work right. Im stumped.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old February 18th, 2007, 11:17 AM   #6
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
I just put an older t45 in my 2000. all the internals are the same but you will have to change the tailshaft and the speedo gear. the sensors mount 2 different ways, mech. at an angle and elec. straight in. the electric gear on the output shaft has to come off and the mech. has to go on. i had to change the bell housing on mine also but not sure if you will have to also.
Threads Similar to: Newbie question. 98 cobra with 99 cobra tranny...Speedo fix?
Cobra R brakes with 2003 10th anniversary cobra wheels...? Gen1sve 99-04 11 September 1st, 2011 12:57 AM
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 13 March 1st, 2011 11:45 PM
COBRA TRANNY ON A GT? WILL IR FIT? adamo41188 99-04 11 July 9th, 2007 06:49 PM
Fluid on my tranny...??? not good... '96 Cobra Slowbra_12 96-98 6 June 7th, 2007 11:36 PM
99 Cobra 5-speed Tranny Mount. Stavsig Modular Mustangs 1 November 3rd, 2006 10:49 PM
