how much will a thicker head gasket reduce compression??
LinkBack (1) Thread Tools
Old September 14th, 2008, 08:47 AM   1 links from elsewhere to this Post. Click to view. #1
1998 mustang GT
ron98gt is on a distinguished road
Cool
ok, i just swaped out my 6lb pulley for an 11lb pulley on my 98 gt.
i have a set of pi heads and intake, the heads have comp cams 270's w/ bee hive springs. the heads are not ported but have been completly done over and re-surfaced. now i'm pushing 11lbs of boost on a stock motor and i would like to install my heads w/out blowing up my motor(i'm not quite ready for a built bottom end yet). if i use a thicker head gasket would that drop compression enough to safely install my heads w/the 11lbs of boost or is that just plain stupid? should i not even bother w/the heads and just run 11lbs, or might i get more out of the pi heads and intake (i can drop from 11 lbs back to 6)? i just waunt to get the most out of my stock motor. i'm thinking i should go w/pi heads and intake w/6lbs of boost(might give me another 100 hp). with 6lbs i added 50hp to the wheels, i'm not sure what i get from the 11lbs maybe 75-90 hp? so i may get a little more from the 6lbs and the pi swap.
98 gt blk on blk 90k miles with BBk 75mm throttle body, C&L plenum, Diablosport predator,powerdyne supercharger & a few other things.
Old September 14th, 2008, 09:27 AM   #2
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
Running a thinker head gasket will eliminate two of the best qualities of the P.I head. Running 10.4:1 compression is not the end of the world with a blower, many have done it without troubles, tune it right and be done. Cylinder head quench, installing a thicker gasket is going to take away the added quench area that the combustion chamber design gives. Honestly taking away these qualities you would almost be better leaving the NPI heads on for the time being or a least until you can afford higher quality internals.
Run the 6# pulley with the pi heads or run 11# with npi heads/ p.i intake and cams. .....
Old September 24th, 2008, 08:05 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
The link will take you to a compression ratio calculator. Fill in the blanks and hit enter and you can determine what each mls gasket will do for you.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 24th, 2008, 08:06 PM   #4
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
sorry, it didn't work.
the link is
Engine Compression Ratio (CR) Calculator
MODS IN GARAGE
NCMM ORIGINAL
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/88863-how-much-will-thicker-head-gasket-reduce-compression.html
how much will a thicker head gasket reduce compression?? This thread Refback September 15th, 2008 03:21 AM
Threads Similar to: how much will a thicker head gasket reduce compression??
Head Gasket andres0286 99-04 1 March 3rd, 2008 09:34 PM
head gasket? RyanGT 99-04 28 February 14th, 2008 03:08 PM
head gasket paulesparza94 94-95 0 January 24th, 2008 02:26 PM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 10:48 PM
head gasket cali 5.0 5.0 Mustangs 3 June 20th, 2006 03:33 PM
