pieces of foam coming out of AC, Also window roles up to high
Old September 15th, 2008, 12:36 AM   #1
1999 mustang Cobra
knightof206 is on a distinguished road
iv'e had 2 mustangs and both of them have had small pieces of oily foam coming out of AC vents any idea what it is. also my window wont close when i shut my door on drivers side now and both my mustangs also did that a 99 and a 01. the windows seems like its going to high and hits small ridge on bottom of roof, my door is aligned right but it seems that my window roles up to high. any ideas on what causes either of these problems?
Lowered, Magnaflow o/r X pipe, Magnaflow MagnaPack Catback, JLT CAI, Livewire Tuner
Old September 15th, 2008, 12:40 AM   #2
Whitehorse's Avatar
2001 Mustang GT
Whitehorse is on a distinguished road
Send a message via AIM to Whitehorse Send a message via MSN to Whitehorse Send a message via Yahoo to Whitehorse
The foam is prabably coming out from where the pieces of AC piping come together. It comes off for whatever reason and blows out. I actually had a Cavalier when I was 16 that blew all kinds of that crap out. No clue about the window though, that's wierd. I'm no sort of body man so I can't suggest anything.
2001 Mustang GT
Bassani Crew Member
Old September 18th, 2008, 02:10 PM   #3
1999 mustang Cobra
ok now my window has fallen off the track and makes bad noises and hits the door handle inside the door, looks like im taking my door apart.
Old September 18th, 2008, 07:17 PM   #4
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Sounds like a problem with the window regulator. The regulator and motor is a PITA to get out, but after you get it out and put it back in, it's much easier the second time around...
"peak hp doesn't mean ish... Its about the area under the curve mannn..."
Old September 22nd, 2008, 01:58 PM   #5
1999 mustang Cobra
i took my door panel off and my window was unglued from my regulater rail, i glued it back but i think its going to come out soon again cuz my window rolls up to high again.
Threads Similar to: pieces of foam coming out of AC, Also window roles up to high
sea foam ??????? armymike63b 99-04 13 August 17th, 2008 01:03 PM
Top Coming Apart from Back Window Dawgs2099 General Tech 1 June 16th, 2008 08:41 AM
Sea foam flattusmaximus78 94-95 3 May 15th, 2008 07:22 AM
Sea Foam Corey 5.0 Mustangs 5 April 17th, 2008 02:32 AM
Help after using sea foam... 04GTAMPA 99-04 4 June 7th, 2007 10:16 PM
