Safest Way to Burn out ?
Old September 16th, 2008, 10:35 AM   #1
DankDaFyed's Avatar
1996 Mustang Cobra SVT
DankDaFyed is on a distinguished road
Cool
ok now what is the best way to burn out on the warm up circle
should i buy a front brake lock kit and set it up that way or what else should i do to burn in the same spot ? (New to drag raceing and dont wanna brake my car)
Old September 16th, 2008, 01:21 PM   #2
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
A line lock won't beat on the rear brakes.
Is it an auto or manual?
*EDIT* - You have a Cobra so it is a 5-speed.
What I like to do is hold the brake with the heel of your left foot and work the gas with the ball. You work the clutch with the left foot. Once the tires start spinning use one foot on the brake and the other one on the gas.
ΜΟΛΩΝ ΛΑΒΕ
Old September 16th, 2008, 02:13 PM   #3
Trick Tuners's Avatar
KB'd GT
LOL, that's on hell of a left foot you got!! But that's how I do it too. Right heel on the brake, toe on the gas, and left foot on the clutch. Hold the brake, rev it up a bit, pop the clutch, then let off the brake until it rolls just a little, then slightly more brake. The key is to use as little brake as possible so you don't cook the rear rotors. Make sure to turn of traction control too!
Old September 16th, 2008, 02:14 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I'd just get a line lock.
Old September 16th, 2008, 02:59 PM   #5
Regency 2007's Avatar
F-150 FX4
Regency 2007 will become famous soon enough
I could burn out with my mach1 without moving forward and keeping my foot off the brake. It would stay in place until the tires got realy hot and then it would start to move forward
Old September 16th, 2008, 04:04 PM   #6
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Same as I do except I don't pop the clutch. I just treat it as if I was shifting normally (ease out of the clutch). But I only do a burnout when I'm getting new tires (every 5 or so years) so I'm not going to invest in a line lock. If you're going to be racing, just get a line lock.
Old September 16th, 2008, 04:57 PM   #7
ponygrrl's Avatar
2003 Mustang GT
ponygrrl has a spectacular aura aboutponygrrl has a spectacular aura about
Send a message via AIM to ponygrrl
A line lock is the safest way and easiest on your rear brakes, you will not wear them out. Otherwise, the heel-toe method works as well.
Old September 16th, 2008, 10:56 PM   #8
DankDaFyed's Avatar
anyone use the hurst line lock kit ? or anyone have any suggestions on a good kit for the anti lock breaks? seems all them at jegs are non anti lock break systems, thanks all!
Old September 16th, 2008, 10:59 PM   #9
ponygrrl's Avatar
2003 Mustang GT
I run the SLP and have no issues. Fairly simple install also.
Old September 16th, 2008, 11:01 PM   #10
00gtCoolGuy's Avatar
13.67 @ 99.3..5000 ft D.A.
00gtCoolGuy is on a distinguished road
+1
LINE LOCK is great!
2000 Mustang GT- 4.10's, Hoosier DR's, JLT, 75 mm TB, Plenum, MAC LT's, VRS O/R X-pipe, MAC Catback
13.671 @ 99.11 (1.80 60')
5000+ ft above sea level - in El Paso, TX
http://www.youtube.com/watch?v=U2l4JdEg3hg
Old September 17th, 2008, 08:44 PM   #11
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
I've always kept my right foot on the gas and dumped the clutch with my left then when the wheels start to spin i'd move my left foot to the brake and adjust the accelerator and brake accordingly. If i ever had to shift, i'd ease my right heel onto the brake pedal while keeping my toe on the accelerator and i'd move my left foot back to the clutch. I'd be sure to give it gas before releasing the clutch to keep the spin, then i'd move my left foot back to the brake and right back to the accelerator.
I think i'll try it the way you guys are doing it. Of course that was pretty much impossible before i raised my accelerator pedal to be even with the clutch and brake.
Old September 17th, 2008, 09:18 PM   #12
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
or you can just rev it to about 4K, dump the clutch, then apply brake lightly, and roast them bad boys
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old September 18th, 2008, 03:49 AM   #13
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I remember my first burnouts, so uncoordinated, it was embarrassing. Now I just do them without a second thought. Just bring the revs up, high-ish and let out on the clutch quickly while getting on the brake slowly, just enough to keep me from moving forward. back breaks last a long time, you will notice tires before breaks as long as you aren't mashing the breaks when you do it.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old September 18th, 2008, 07:44 PM   #14
Its not so much the wearing of the pads as it is the fact that you're heating the rotors with large amounts of friction and hot wheels and tires. I mean the spinning wheels fighting a braking force will put a lot of unnecessary heat on the rotors that normally wouldnt occur.
"peak hp doesn't mean ish... Its about the area under the curve mannn..."
Old September 18th, 2008, 10:58 PM   #15
DankDaFyed's Avatar
i have heard of people warping there rotors or breaking there clutch but i think you about run the same risk on the clutch with or without the line lock, it definetly is a bit tricky at first after a few runs i had some nice burn outs but not as good runs lol i have aquired some drag mickeys tomps at the track last night for cheap well see how they light up next week
Threads Similar to: Safest Way to Burn out ?
Safest / nitrous jets? JTS V6 Mustangs 8 August 18th, 2008 08:52 PM
safest and most efficent S/c? DeMello 99-04 21 May 5th, 2008 11:07 PM
Ford / Honda Safest Cars Ninjawafers! The Clubhouse 4 November 15th, 2007 03:27 PM
Mustang Proves To Be The Safest Convertible WilltheThrill General Tech 3 October 31st, 2007 12:53 PM
safest horsepower KhaosGT General Tech 21 September 26th, 2007 10:22 AM
