1999 4.6 cobra camshaft position sensor
Old December 7th, 2006, 08:34 AM   #1
lovedr79 is on a distinguished road
Hi! just joinded today, had a new 4.6 put in my wifes 1999 cobra, now the computer is throwing the P0340 camshaft position sensor cirsuit malfunction. does this sensor need to be set in time with the new motor or do i need to just put a new sensor? also is there a special alignment tool i need to set this in time? if so anyone have the part numbers? Thanks!
Old December 7th, 2006, 11:38 PM   #2
1999 Mustang
Invictus is on a distinguished road
i guess nobody knows or else they'd have answered your question.. i dont know either but in an attempt to help i'd just change the sensor out and see if it still throws the code. has the car been idling rough or anything out of the ordinary? if not, just change the sensor its behind the power steering reservoir.
Old December 8th, 2006, 01:46 PM   #3
2002, Mustang GT
7.5@98 in 1/8
yellowfever is on a distinguished road
I had the same problem in my 2002 gt. I replace the camshaft position sensor twice and the code still. To do the long story short, all the problem was the alternator. I do not know the theory behind that but i fixed the problem.
Old December 10th, 2006, 04:18 PM   #4
Casper98GT's Avatar
Yellow, its strange you got that problem in youre 2002. Yes the alternator can set a p0340. Sounds strange, but it can happen. First check to see if its plugged in and has a good contact. Check voltage to it, to make sure something didnt get clipped when the engine went in.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old December 11th, 2006, 07:29 AM   #5
thanks! i replaced the sensor, so we will see what happens when my wife drives to work today. i drove it around for about 10 minutes nothing came up. so we will see. i did try to check the old sensor with a volt metere and waving a piece of metal past it i got no voltage spikes. so hopefully that what it was. the alternator does seem to be charging aswell.
1999 Cobra convertible
1966 Mustang coupe 289
Run it like you stole it!
May the bridges I burn light my way!
Old December 11th, 2006, 07:50 AM   #6
well no sooner than i posted my phone rings its my wife, the check engine light is back again. so i guess i will be replacing the alternator
Old December 27th, 2006, 10:55 AM   #7
well replaced the alternator, CEL still on. any other suggestuions?
Old December 29th, 2006, 04:22 AM   #8
1999 Mustang
may want to voltage check the harness plugging into the sensor itself, you may need to take off the power steering resovoir to get to it. make sure its a good connection. and make sure nothing is on the magnet if all checks out i'd try the dealership. does the car idle any different or run sloppy since it threw the code.. its throwing that code for some reason... hmm
Old January 2nd, 2007, 10:10 AM   #9
what should that voltage be? we were trying to figure it out this past weekend, but to no avail we didnt figure it out. the car runs fine, idles fine so i am stumped on this one.
Threads Similar to: 1999 4.6 cobra camshaft position sensor
'00 Crankshaft Position Sensor mbooz02 99-04 5 November 8th, 2007 05:24 PM
camshaft positioning sensor mmvi V6 Mustangs 7 August 4th, 2007 02:01 AM
P0340 Camshaft Position Sensor Circuit Malfunction autostang03gt 99-04 4 January 14th, 2007 09:48 PM
Throttle Position Sensor And Power Adders stangempire82 99-04 1 November 19th, 2006 08:14 PM
P0340 camshaft position sensor yellowfever 99-04 1 October 9th, 2006 11:19 AM
