thinkin about running nitrous...
Old October 8th, 2008, 10:13 PM   #1
1999 SVT cobra
99svtcobra66 is on a distinguished road
Send a message via AIM to 99svtcobra66
Exclamation
So I am deciding whether or not to go the S/C route or the Nitrous route. I am completely undecided. but lets say i decide to go nitrous. I was thinking about NX 100 shot( do i need forged pistons to handle it or is my stock engine going to hold up? cant afford to pay for anything over like 1500) but what would be a list of everything I need/ prices. any help greatly appreciated.. thank you!
99 SVT cobra
Old October 8th, 2008, 10:35 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Search it man, there is a topic a week about this. but a quick answer is no you won't need to go inside the motor for a 100 shot. you will spend most of that 1500 for a good setup with heater, window switch, colder plugs, and a tune if you do it the right way and don't cut any corners you can spray that 100 shot all day and be good to go. Just remember if you cut corners you can be looking at engine damage so get everthing you need.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old October 8th, 2008, 10:39 PM   #3
1999 SVT cobra
ya i figured i would just get the nx 100 shot kit, bottle warmer, plugs, tune. but i dont need bigger injectors or anything? ( i know i shoulda searched i just get lazy haha sorry)
99 SVT cobra
Old October 8th, 2008, 10:44 PM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
No you won't need injectors for the 100 wet shot. make sure you get a good window switch as well. And as for the bottle heater get a pressure controled one not a temp controled. Dyno Tune has a great pressure heater setup and its fairly inexpensive. Thats the only heater I run. I was running a dual 10lb bottle setup with 2 dyno tune heaters and one dyno tune pressure sender. It worked flawlessly.
Military Crew
U.S. Army Aviation
Old October 8th, 2008, 10:53 PM   #5
1999 SVT cobra
so i need nx 100 shot kit, pressure heater, plugs, tune, window switch. ( whats a window switch exactly?) and should i get the steeda arming switch it looks pretty sweet
99 SVT cobra
Old October 8th, 2008, 11:08 PM   #6
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
the arming switch is up to you, its personal when it comes to that. The window switch controls what rpms the nitrous will spray. so lets say you want it to only spray from 3500-5500, then you just set it for 3500 rpm to come on and 5500 rpm to go. I reccomend the MSD digital RPM window switch, its the easiest to use and you can adjust your on/off rpms with just a touch of a button. It is a good investment because if you spray too early your can have a backfire or blow a hole in the piston and if you spray too late, like if you hit the rev limiter on the spray, you will be in a very lean situation and it will almost definatly pop the motor. You want to shut it off a couple hundred rpms before rev limiter and you don't want to spray before 3k rpm. So if your rev limiter is 5800 lets say then set your window swithc for like 3200 on and 5500 off, that will give you a good starting point and you will be able to make adjustments from there. also when you do more mods and the car can make power higher in the rpm band then you can spray a little longer with a higher rev limiter. Make sense?
Military Crew
U.S. Army Aviation
Old October 9th, 2008, 06:13 PM   #7
1999 SVT cobra
ahh i see.. ya that makes sense. thanks a bunch doc
99 SVT cobra
Old October 9th, 2008, 08:00 PM   #8
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
No problem man
Military Crew
U.S. Army Aviation
Old October 9th, 2008, 11:00 PM   #9
RavensChild's Avatar
1998 Mustang Coupe
Amazing
RavensChild will become famous soon enoughRavensChild will become famous soon enough
i say S/C over nitrous. The s/c doesnt need to be filled and is always there for you. But it will be a hell of a lot more though.
HARDCORE CREW
dude, be the first person in history to sue somebody for not letting you polish your dolphin while looking at porn.. you'll become a legend
Threads Similar to: thinkin about running nitrous...
i've been thinkin... adrenaline=lifeline 99-04 47 October 2nd, 2008 11:46 AM
Who running Nitrous? Street_Racer 2.3 Mustangs 53 September 7th, 2008 01:55 PM
Running Nitrous On A Termi Smoothgrandmama 4V / SVT 31 July 18th, 2008 03:07 AM
anyone running nitrous on their stang? e3sean 5.0 Mustangs 14 April 2nd, 2008 09:58 PM
These are what i'm thinkin...what do you think? D-Brow V6 Mustangs 35 February 12th, 2008 05:20 PM
