Discussing The Official Suspension Guide in the Modular Mustangs Forum. Thanks for all the help bro!...
Old September 2nd, 2009, 03:05 AM   #261
PapaSmurf's Avatar
2003 Mustang GT
13.86 @ 100.87
mods listed in garage
Old September 14th, 2009, 07:29 PM   #262
Genibus Nitito Canus
HBK_2007's Avatar
next year
what kinda suspension mods does it take to do a wheelie?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, some type of exhaust, "leveling kit"
Old September 16th, 2009, 12:51 PM   #263
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
You can do it with the stock set up if you have enough power. The requirements to do it repeatedly are more along the lines of stong parts so the car won't break.
I'd say if you have about 800rwhp and sticky enough tires, you can get the tires off the ground if you have a tubular front k memeber, a arms and no sway bar. Coil overs all around. A new set of extreme duty rear lower control arms, a set of adjustable uppers. Full Cage and some fat ass slicks. Very doable. Remember, the lightness up front makes it easier, and the traction makes it happen. Nothing more than your normal suspension parts are required. Its really more about the power and traction.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
PI Swap
Spun Main Bearing...
Author of The Official Suspension Guide
Old September 16th, 2009, 07:17 PM   #264
HBK_2007's Avatar
next year
could it be done N/A (about 350 vs 800 rwhp)? i think that would be awesome to be at a stop light, have some douch civic pull up and wanna race, then do a wheelie
Old September 16th, 2009, 10:10 PM   #265
Thumbie's Avatar
'96 Mustang GT
15.52@90.4
you would have to do a faaaat burnout to heat up your faat slicks first
Eibach Sportlines and Pro-Dampers, Flowmaster 40's
Old September 17th, 2009, 09:10 PM   #266
1997 Mustang GT
Faster than an s4
If you had some hugely fatty slicks. A total drag suspension set up. All tubular front with an aluminum block and every lightening thing you can find. You might be able to pop a wheely at a light with 400hp. But its going to be REALLY unlikely.
With street slicks there was a guy I knew of on Mustang Forums running a 800hp KB termi, that could get his front wheels off the ground on the street. Not a full on wheelie, but he could hop them off the ground. This guy had the works for suspension though. Were talking an all out drag car.
On the street you have to also remember, there is no rubber groove to help your traction. So you have to really have monster traction and power to even think about popping that thing off the ground. Now move the engine into the trunk, now you might have a chance.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
PI Swap
Old September 18th, 2009, 11:44 AM   #267
HBK_2007's Avatar
next year
oh dang, there goes that idea
Old September 18th, 2009, 01:43 PM   #268
Thumbie's Avatar
'96 Mustang GT
15.52@90.4
ha ha well it was a good question, though. I kinda wanted to know, too
Old September 19th, 2009, 02:33 PM   #269
HorsepoweR's Avatar
1996 Cobra
N/A Yet
I got a question, if you have bad shocks will they make a noise that sounds like metal on metal clanking?
.:.Mods In Garage.:.
F
ound
On
Road
Dominating
MM Fantasy Football - SVT SNAKES - 7-3
Xbox360 Tag - SVT JUGGALO
Old September 20th, 2009, 05:29 PM   #270
TorqueO's Avatar
Ok seeing that this is a suspension guide I have a question on rear coil overs.
Just installed some MMR rear coilovers 12"-250lbs springs with Comp Engineering 3 way drag shocks and not happy. The shocks are set at 50/50. The Mustang sits at stock ride height or a bit higher. I have adjusted it so that there are only 4 threads still left.
Why am I having this problem?
The rear of the mustang is sitting 3 1/2" higher than the front. The front has Eibachs sport lines and Tokico struts.
Everything went in smooth and was to remove a "rear upper shock mount" but could not see or find any.
Old September 20th, 2009, 10:36 PM   #271
1997 Mustang GT
Faster than an s4
The bad shocks may make a clunking sound if they are bottoming out and stuff. I would take it to a shop though, its hard to diagnose a sound without hearing it.
The rear coil overs has a couple of things. One is, everything is installed correctly? Next, are you sure that is the correct spring length. I believe you can get a 10" spring that will give you a greater range of adjustability. I would call Maximum Motorsports and talk to them, they are fantastic to talk to.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
PI Swap
Old September 21st, 2009, 12:34 AM   #272
HorsepoweR's Avatar
1996 Cobra
N/A Yet
alright, thanx man
F
ound
On
Road
Dominating
Old September 21st, 2009, 02:33 AM   #273
Thumbie's Avatar
'96 Mustang GT
15.52@90.4
torque: how many miles are on the springs? it takes a couple hundred for them to settle
Old September 21st, 2009, 08:32 AM   #274
TorqueO's Avatar
Thanks guys!
The springs are brand new and everything was install according to the instructions. Didn't even take it out for fear of doing damage.
I was also told last night that maybe I should have gone with a shorter spring.
I'm going to call MMR in a couple of hours and see if they can shead some light.
I will post up what they say, I was trying to figure this out without calling them oh well.
Old September 21st, 2009, 01:18 PM   #275
1997 Mustang GT
Faster than an s4
In general I would agree, but Maximum Motorsports are such great guys to talk to. I wouldn't hesitate calling them.
Its true the spring will settle, but they will not settle 3 inches.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
PI Swap
Old September 21st, 2009, 01:47 PM   #276
EscortSportage's Avatar
1989 Mustang GT 5.0
heres my question, if u really want ur stang to handle and carve corners, why dont u just convert to a 03-04 cobra IRS and scrap the donkey kart technology for a rear end. I keep debating this...
CAI,MSD,Xhaust
Ctrl arms,TRQ boxes,
SubFrame Connectors
EiBach/Tokico
Front/Rear strut/shock braces
CheaterSlicks
3.55's
"a huge bad azz motor is nice untill you have to turn or stop"
Old September 21st, 2009, 01:55 PM   #277
HBK_2007's Avatar
next year
thats been discussed alot in this thread if u read the whole thing
Old September 21st, 2009, 02:01 PM   #278
1989 Mustang GT 5.0
damn lol, i read up to the 4th page then skipped. maybe i shouldnt have done that
CAI,MSD,Xhaust
SubFrame Connectors
EiBach/Tokico
CheaterSlicks
3.55's
Old September 21st, 2009, 07:33 PM   #279
TorqueO's Avatar
OK I called MMR before noon E.S.T. (Modular Mustang Racing...they are a good brand and pretty much equal to MM) and we discussed all of the questions I had. Ended up that everything was done correctly, it is just the height of the spring was way to much. MMR told me to go with a 10" spring but I opted for a 9" spring seeing that I have all that adjustment. I might take pics after the shorter springs are installed.
Old September 21st, 2009, 09:58 PM   #280
1997 Mustang GT
Faster than an s4
Sounds about right.
The IRS question has been torn apart pretty good. The best answer I have not seen yet though. There was a guy posting a while back about their IRS set up that they put in instead of the 3 link set up. I want to see what their results are since the switch.
To answer the question simply, the IRS is actually a bit worse than the 3 link. You can read the rest of the thread for the reasoning.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
PI Swap
Threads Similar to: The Official Suspension Guide
a/c removal guide? dmac45 94-95 0 June 5th, 2008 06:12 PM
install guide 01silversnake 99-04 1 September 24th, 2007 09:05 AM
Guide To Building A 4.6 man_of_war2081 99-04 7 February 25th, 2007 06:40 PM
Funny Guide To Modification thewayshemoves The Clubhouse 0 December 24th, 2006 05:46 AM
289 hi-po guide 99mustang232 Classic Mustangs 6 December 5th, 2006 11:33 AM
