The Official Suspension Guide - Page 17
LinkBack (32) Thread Tools
Old October 28th, 2009, 03:39 PM   #321
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Originally Posted by ReverendDexter View Post
My understanding is that the torque arm setup grips HARD for launching due to the instant center it provides. However if you're just doing drag racing, the additional cost over adjustable uppers and lowers probably isn't worth it for the gains you would see. The adjustable upppers and lowers will also allow you to change your setup based on the track condition.
I know that I can't have both great cornering and great straight line, but would this setup allow me to have a nice drag car that could also corner decently? I probably won't do any autocross, but I love driving hard on the twisty roads around here, and I don't want to lose that...
Depends on what part's adjustable. Usually adjustable LCAs allow you to adjust the height of the spring perch, which would be totally unnecessary with coilovers. Adjustable UCAs are usually adjustable length, which allows you to dial in your pinion angle, which I understand to be HUGE in terms of launch grip.
I've heard the opposite, that pinion angle doesn't really have anything to do with traction. If I understand correctly, pinion angle is just the angle between the differntial and the driveshaft. If it's off quite a bit, then it will rob horsepower. But as far as traction is concerned it doesn't make a difference what angle that u-joint is at. Anyone to confirm or deny?
How would you adjust the pinion angle if you don't have adjustable UCAs? Say if I go to a panhard bar/torque arm setup and got rid of my UCAs alltogether?
One thing I will add here is that if you go the 4-link route, make sure to get UCAs with spherical joints, not the kind with poly bushings. Polys are okay in the LCAs, though having a spherical joint on at least one side is definitely preferable.
I've heard this before and will make sure to get the spherical joints
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old October 28th, 2009, 04:29 PM   #322
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
As far as cost goes, a nice 4 link set up will be cheaper. And it will not be any worse than it already is at cornering. If you want to take it a step further, the best suspension for both drag and turning is the 3 link for a non-irs.
The torque arm allows you to set the pinion angle to be nothing. Your stock 4 link set up is expecting axle wrap, so the pinion angle is set off so that the axle twists and the angle becomes correct.
If you are confused on the pinion angle effect. Take a socket wrench with a universal on the end, twist it straight on and twist it at an angle. It works, but you are losing a lot of mechanical advantage at an angle.
The torque arm is the bar none best option. But it costs a bit.
Rear coil overs make an adjustable LCA meaningless. (adjustable spring perches that is, not length)
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old November 10th, 2009, 05:00 AM   #323
ferk is on a distinguished road
hey hi to all a very nice post and good information given.
Old November 23rd, 2009, 06:15 PM   #324
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Originally Posted by ModMustang97GT View Post
Aftermarket sway bars are too stiff for the coil overs. The job of a sway bar is to make sure that the wheels move together.
The problem is, the design of them is simply a bandaid. Ideally you wouldn't have any sway bar at all, but at least in our case, this isn't really an option. So, when you get coil overs, they tell you to keep the stock sway bars. Otherwise, the sway bar will be subtracting from your coil over's ability to absorb the shocks. You are essentially adding the stiffness of the sway bar to your spring rate. But its not in a good way, it is hindering its movement both up and down. So adding to the wheel rate in the up direction, and subtracting in the down direction. There by making the wheel actually track worse.
In a corner, an overly stiff sway bar will cause the inside wheel to actually pull up off of the ground in a hard corner. So, the weaker the sway bar can be and still do the job the better.
Jazzer went through this all very recently. He didn't want to swap in a stiffer set of springs for his car due to ride quality issues. So he invested in an adjustable sway bar. It helped to dial in some needed Over steer, but it was highly recommended against by Bruce Griggs (owner of griggs racing), because of the negative affect on the wheel rate.
If you suggest sticking with a stock rear sway bar, why does MM include an adjustable one with their Maximum Grip Box which comes with front/rear coilovers? Not implying that you are wrong at all, but I'm just wondering if I ever save up enough money to buy this Grip Box, if I could tell them that I don't want the sway bar to save a little money. Especially since you say I really don't want it with the CO setup.
The Rev is right. Your can get a pretty decent all round shock in the D-Spec, but you are not guaranteed the best handling or best launch. The reason being, you can't change your spring rate. You can try and get an all round good set up, but its not going to exceptional at either. Fortunately, with coil overs, it will still be better than any set up you get with the modified macpherson strut.
I'm a newb when it comes to suspension, spring rates, and matched struts/shocks so forgive me if this is really stupid. I'm going to throw an idea out there and you guys (rev, modmustang) are going to tell me why i'm wrong or why this wouldn't work well.
It's my understanding that coilovers use a linear spring design. Why couldn't they put a progressive spring in there? Then if you wanted less spring rate you lengthen it out so the spring is in more of a free position and if you wanted a higher spring rate you could shorten the coilover so the spring was compressed more. Probably be kinda hard to dial in your adjustable shocks, but you could probably get close.
Old November 23rd, 2009, 06:44 PM   #325
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Because that's not how coil-overs work.
In adjusting the ride height, you're not adjusting the length of the spring, you're adjusting the length of the strut. The only effect changing the height has on spring rate is due to the amount of weight exhibited on the spring at rest (lowering a corner increases the resting weight at that corner).
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old November 24th, 2009, 11:02 AM   #326
El Danno
dcook_14's Avatar
iTrader: 7 reviews
I knew I was missing something in my logic. Thanks Rev, and thanks for the help in the other thread about the adjustable sway bar. Just trying to get everything straight before I dump a bunch of money on suspension parts, I don't want to get things that don't work well together.
Old November 26th, 2009, 08:51 PM   #327
EscortSportage's Avatar
1989 Mustang GT 5.0
so from what i understand for a top live axle rear end set up, you would do:
PHB
good LCA's
torque arm setup
with coil overs
10 point Cage
Bunch of newer mustang parts
Maximum Motorsports catalog
Sparco stuff
"a huge bad azz motor is nice untill you have to turn or stop"
Old November 26th, 2009, 10:50 PM   #328
El Danno
dcook_14's Avatar
iTrader: 7 reviews
PHB
good LCA's
torque arm setup
with coil overs
Really depends what you mean by top (which I assume means best) live axle setup. I'm looking into autox and twisty driving, so yeah the combo you stated will be a good start. Don't forget the SFC and maybe a rollcage, swaybars, and maybe additional things.
This is probably not the way to go for drag racing. I understand it's a lot cheaper and just as effective (if not more effective) to just stick with the four link with good adjustable upper and lower control arms and a nice set of adjustabel shocks/struts and drag springs. SFC and maybe a roll cafe for this setup too though.
Old November 27th, 2009, 03:37 PM   #329
1989 Mustang GT 5.0
i already have front and rear strut/shock tower braces, and through the floor subframe connectors,Eibach sportsline springs,tokico illumina adjustable shocks, MM camber caster plates, now i need to finish up the front and rear suspension ie:
tubular k member
tubular a arms
coil over conversion all 4
and the stuff i mentioned above
10 point Cage
Sparco stuff
Old November 27th, 2009, 04:23 PM   #330
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
(but sure he would not be happy about it)
I really only got a bit of disappointment from John, his brother. Unless John had mentioned it to him yesterday, he doesn't even know I have installed the MM sway bar. I actually brought my car up there this past Monday and had him install a brake bias proportioning valve to give me some additional rear brakes. At first, John was not soo happy I had installed the bar, but explained the issue you mentioned above, and said it is not such a big deal. He later test drove my car after his work and said "I can see why you didn't want to change the springs/shocks... you car rides really nice".
I realized then, and repeated it to John, that my car is a full-on DD ride and not willing to have the ride necessary to avoid the need for a heavier sway bar. It is a compromise, to be sure, but no regrets at all
Jazzer
EDIT: 'Tis true that ideally one would not have a sway bar at all and could run without one with the proper set-up
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old December 1st, 2009, 07:02 PM   #331
1997 Mustang GT
Faster than an s4
Jazzer I thought you said in a PM to me that Bruce was against getting a different sway bar?
Anyway, the reason the grip box comes with one is the grip box is an ADJUSTABLE suspension. Meaning, you can install it, go to the track and dial it all in. Depending on a whole bunch of different conditions, you may need to adjust the effective thickness of your sway bar to make it react the same way in different places. Temperature, tires, altitude, weight of the car can all make a marked difference in your handling.
On a side note, I just spent about a week prowling the corner carvers forums. I now feel utterly stupid about suspension. A couple of the guys that worked on the team that developed the steeda 5 link set up post over there.
After reading their info, I think the 5 link is an awesome set up, still not a huge fan of it, but its deffinitely a viable option compared to the TA 3-link. Has its own set of issues of course, but should be just as competitive. Sounds like the only true solution to our solid rear axle, which according to the experts has been an uncompetitive set up for 40 years. Is to set up an almost entirely custom 3 link with a torque arm that requires murdering the rear half of your mustang. Crazy stuff.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old December 1st, 2009, 09:00 PM   #332
3rd Place '11 ROTY
19.34@42.259
CC has a way of making one feel like a dummy, huh?
I know I sent you a PM on the subject and can understand how you may have thought Bruce was against it. I remember saying that I was sure he would not approve, so figure that is where you got it from. Even though he never told me such, I have zero doubt he would feel exactly the way you mentioned on post #300.
The bar I installed handled my issue perfectly, so I am a happy kitty
Jazzer
PS. 331 responses to your thread... pretty good! Now if you can only catch MM Cobra Club thread
Old December 2nd, 2009, 01:52 AM   #333
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
tubular k member
tubular a arms
and a torque arm and watts link
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old December 2nd, 2009, 12:05 PM   #334
El Danno
dcook_14's Avatar
iTrader: 7 reviews
He already said that, it's part of the "and the stuff I mentioned above" part of that post. He said torque arm and panhard bar.
Old December 2nd, 2009, 01:18 PM   #335
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
ah, thanks for pointing that out. although I believe it was discussed that the watts link is slightly superior to the PHB, right? don't remember exactly why but something like the angle of rotation on a PHB is on the side. I don't know but still handling-wise there is hardly a difference, but if he wanted TOP suspension then Watts link is what he wants.
correct me if im wrong, this is a learning thread not a "your a dumbass STFU thread"
Old December 2nd, 2009, 05:35 PM   #336
1997 Mustang GT
Faster than an s4
This is definitely a Learning thread. But if someone comes in and does try to pass off hearsay as truth I will be forced to call them out.
In general the Watts link is generally considered better, but there are some issues with it. Ultimately its heavier and unlike the panhard bar does have a max range of movement. Though the range is quite large and the location is absolute as apposed to the PHB which depending on the distance from resting height, will move slightly through the arc of the rod.
Also, most watts links require you do partially mame your trunk to get them in correctly.
And, with the PHB, you are also able to design a fewer link suspension set up that will be MUCH lighter than a WAtts link set up and still have the same ultimate performance. Granted that is WAYYYY beyond the bounds of 99.9999% of people reading this threads goal, its worth mentioning.
PS. I feel like luke in return of the Jedi right now. I have returned with a new level of suspension understanding. (CC awakened part of my brain I haven't used since I got kicked out of engineering school).
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old December 25th, 2009, 01:29 PM   #337
1989 Mustang GT 5.0
so this is my plan MM lower control arms no perchs (coilovers) MM PHB MM torque arm setup for rear with stock sway bar and i have torque box reinforcements already,
for front im thinking MM k member MM a arms, coilovers MM strut tower brace, stock sway bar
eventually a 10 point cage
i also need/want MM bumpsteer kit, 5 lug conversion, rear disc brakes, bigger n better brakes
10 point Cage
Sparco stuff
Old December 26th, 2009, 03:53 PM   #338
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Good to know, thanks for clearing that up.
My goal will never be intense enough to require the watts link, then.
I think what i want is basically the MM grip box, lol...someday...
Old January 8th, 2010, 09:42 PM   #339
1989 Mustang GT 5.0
i want to do the PHB over the watts link cuz its lighter, i think stronger due to less moving parts...
10 point Cage
Sparco stuff
Old January 9th, 2010, 12:40 PM   #340
Lighter, certainly. Stronger? I don't believe so.
All the stress on a panhard bar is going against one long bar and two joints. With a watts link, you have shorter bars (shorter is stronger, all else being equal), and 5 joints to spread that same stress across. More points of failure, sure, but I don't think it's inherently weaker because of it.
O o
\_\
Last edited by ReverendDexter; January 9th, 2010 at 05:26 PM. Reason: massive grammar fail
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/92453-official-suspension-guide.html
Best lowering springs and caster camber plates for the money ? - Page 2 - MustangForums.com This thread Refback October 27th, 2011 07:05 PM
Dutch Ford and Mustang Forum - DM&FF • Toon onderwerp - Mustang 89-04 informatie This thread Refback June 15th, 2011 10:57 AM
Dutch Ford and Mustang Forum - DM&FF • Toon onderwerp - Link: Suspensie uitgelegd 89-04 This thread Refback May 18th, 2011 05:00 PM
Dutch Ford and Mustang Forum - DM&FF • Toon onderwerp - Link: Suspensie uitgelegd 89-04 This thread Refback May 18th, 2011 03:50 PM
Kit de suspensión regulable para golf III - equiv Anuncio Clasificado en Joyas Se Vende, A Coruña This thread Refback May 8th, 2011 06:49 PM
Good Suspension Info This thread Refback March 18th, 2011 04:15 PM
Good Suspension Info This thread Refback March 18th, 2011 04:11 PM
Clunking noise in rear after being lowered - Ford Mustang Forums This thread Refback January 8th, 2011 07:54 PM
Info.com - griggs sla wheel rates - www.Info.com This thread Refback December 27th, 2010 12:07 AM
2000 supercharged Roush F150 This thread Refback November 11th, 2010 05:32 AM
2000 supercharged Roush F150 This thread Refback November 11th, 2010 05:29 AM
Mustang Performance Shop Md - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback January 10th, 2010 04:15 PM
Best lowering springs and caster camber plates for the money ? - Page 2 - MustangForums.com This thread Refback July 30th, 2009 07:18 AM
Air Ride Suspension Kits on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 12th, 2009 01:50 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback July 7th, 2009 06:33 PM
Air Ride Suspension Kits on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 2nd, 2009 12:38 AM
car, parhard | VIRGILIO Ricerca | Web This thread Refback June 24th, 2009 08:53 AM
lower control arm bushing upgrade - MustangForums.com This thread Refback May 4th, 2009 10:42 PM
MacPherson Strut Tag | Used Volkswagen Beetle This thread Refback February 23rd, 2009 01:13 PM
DM&FF :: Bekijk onderwerp - Informatieve links (courtesy of www.moddedmustangs.com) This thread Refback January 3rd, 2009 11:56 PM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 25th, 2008 10:15 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 24th, 2008 06:28 PM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 21st, 2008 06:07 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 19th, 2008 06:53 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 18th, 2008 04:06 PM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 18th, 2008 03:19 PM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 18th, 2008 09:38 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 18th, 2008 08:40 AM
DM&FF :: Bekijk onderwerp - Amerikaanse benaming This thread Refback December 18th, 2008 08:15 AM
DM&FF :: Bekijk onderwerp - Informatieve links (courtesy of www.moddedmustangs.com) This thread Refback December 16th, 2008 09:39 PM
DM&FF :: Bekijk onderwerp - Informatieve links (courtesy of www.moddedmustangs.com) This thread Refback December 16th, 2008 06:23 PM
The Official Suspension Guide This thread Refback October 11th, 2008 03:37 PM
Threads Similar to: The Official Suspension Guide
a/c removal guide? dmac45 94-95 0 June 5th, 2008 06:12 PM
install guide 01silversnake 99-04 1 September 24th, 2007 09:05 AM
Guide To Building A 4.6 man_of_war2081 99-04 7 February 25th, 2007 06:40 PM
Funny Guide To Modification thewayshemoves The Clubhouse 0 December 24th, 2006 05:46 AM
289 hi-po guide 99mustang232 Classic Mustangs 6 December 5th, 2006 11:33 AM
