LinkBack (32) | Thread Tools |
#341 |
I like to go to Subway because the women there have to make ME a sandwich. |
#342 | |
1989 Mustang GT 5.0
time and money....
10 point Cage Bunch of newer mustang parts Maximum Motorsports catalog Sparco stuff "a huge bad azz motor is nice untill you have to turn or stop" |
#343 |
1999 Mustang GT
i just bought KYB shocks gas-a-just and i'm wondering how to match the right springs, from my understanding the shocks should absord the springs movements so the car doesnt swing all the time.
Do you guys have any suggestions for a set of springs? Thanks |
#344 | |
Priest of the Car Gods
Gas-a-justs are an entry-level shock, and are really designed to be paired with an OEM spring rate. I'd run 'em with stock springs or FRPP C-spings. You can probably get away with running a heavier spring, but the match will be less than ideal.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#345 | |
2001 Cobra
14.2@102 (I suck)
Edit: oops, didn't mean to make the text that big lol
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 Last edited by Thumbie; February 26th, 2010 at 01:04 AM. |
#346 | |
1999 Mustang GT
i'm not looking to build an awesome rear suspension, just replace the 11 years old springs and shocks. So i could go with Ford racing C springs, that would be your recommendations? |
#347 |
Yeah, if the C-springs are the ones I think they are, they're same rate as stock, only with a 7/8" drop. Would be a good replacement that's not a drastic change like a pro-kit or H&R super sports.
#348 |
1999 Mustang GT
Taken from ford racing website
"Fits 1979-2004 Mustang Lower your Mustang and improve handling The height on some cars will vary PART NUMBER MODEL YEAR AMOUNT LOWERED (V-8) SPRING RATES (LB./IN.) FRONT REAR FRONT REAR M-5300-B 6 1979-04 5 .875" 1 .5" 2 425/530 200/300 M-5300-C 6 1979-04 5 .875" 1 .5" 2 650 200/300 M-5300-F 3,6 1979-04 5 1.2" 1.0" 460/570 170/310 M-5300-G 4,6 1979-04 5 1.2" 1.2" 500/570 170/310 NOTES: Expect some deterioration in ride quality 1 1994-2004 models – 1-1/8" 2 1994-2004 models – 3/4" 3 Coupe only 4 Convertible only 5 Will not fit 1999-2001 Cobra 6 Due to vehicle assembly tolerances these specifications may vary." hmmm, by Expect some deterioration in ride quality, what do they mean exactly, i'll feel the bumps on the road more? if that's the case that kinda suck ? |
#349 | |
The flipside of this is to increase the spring length such that impacts cause a 1 Hz oscillation in the spring. But I don't think many people here would want a Mustang on Baja suspension: ![]() Bask in the AWESOME.
#350 |
1999 Mustang GT
lol, nice car...
btw how stiffer are the FR c-springs compared to the stock ones ? |
#351 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
That stangsuspension.com company in the OP has closed the doors.
#352 |
1997 Mustang GT
Faster than an s4
Yeah. Unfortunately I am not able to edit the first post of this anymore. Really too bad. It would be nice to take the re-assembled list of information and put it as the first post so everyone wouldn't have to search so much for it.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
#353 |
so if i went and got the ford racing springs i wouldnt need much, i believe the only lower the car around an inch witch is all i want becuz of were i live lol
DRIVE IT LIKE YOU STOLE IT |
#354 |
Most likely all you'd need is an alignment afterwards. Really depends on what shape your shocks are in now, and how sensitive you are to bumpsteer.
#355 |
Looking for some help
Hello, I am new to the forums and have a 1994 Cobra. Great information in this post and I found this in looking for information on my next suspension mod, unfortunately, based on what I have read on this forum, I think I made some mistakes on the mods I made past year.
My car has a little over 100,000 miles and the suspension was original and stock and was in need of some updating. I installed/added the following parts last year: - The Ford Racing Bullitt suspension kit (M5400A) - MM Full length subframe connectors - MM Strut tower brace - UPR Upper and lower control arms (79-98 Mustang Elite Chrome Moly Urethane Control Arm Suspension Kit) The car see mostly street use with occasional trips to the drag strip, so while hooking up is important, street handling is most important. Based on what I have read, the UPR kit was a mistake. I don’t think I have pushed it hard enough in the corners to experience the binding, but I don’t want to experience the problems first hand. Am I right, was the UPR kit a mistake on a mostly street driven car? If so, what is the best avenue to correct the problems? Would it be to keep the UPR lowers and go with something like this, Rear Upper Control Arms, solid axle, 1979-04 [M-5500-A] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader! for the uppers? Or should I also replace the lowers as well? Thanks for all the great information in this thread. |
#356 |
Honestly, I'd keep your current lowers, and just get a set of uppers with a spherical joint. The ones I've seen are usually around $180/set, and for the MM UCAs (which are stock arms with slightly stiffer rubber bushings) you're already looking at $130 of that.
#357 |
Great write up, thanks!
01 Gt Vert, Murdered Out, Bama Tuned, 4.10's, Vertical Doors, K&N Intake, Trickflow Plenum Throttlebody, Reverse Glow Gauges, Steeda Pulleys, Shift Kit, SLP Loudmouths, H&R Sport Springs Chin Spoiler, Saleen Tonneau Cover, Billet Race Pedals |
#358 |
1997 Mustang GT
Faster than an s4
The Rev has the right idea. the UPR Uppers are going to be worse bind than the stock set up. Mind you it will come much later now, it will also be more violent. That being said, its not going to cut your car in half or some catastrophic thing.
Here a good idea of what the feeling we are describing in the snap steer. I'm sure everyone has at some point decided, "I'm going to take off out of this driveway, and power slide it out, then eas off of it and take off down the road". Then when you try to do that, the car goes a little further than you expect, and to recover, you spin the wheel to opposite lock, the rear end rebounds in the other direction following your lead. As you do this, instead of the car really settling down, it snaps to each side and your traction gets worse and worse, the only hope is that you have lost enough speed to get the car within the limits of the suspension again. With a PHB or Watts link, this doesn't happen. With the stiffer aftermarket uppers, your still going to get the same effect, but the tollerance of the suspension is higher, so you will need to be pushing harder to get the suspension to snap from side to side. But when you do, it will be much harder than the stock suspension does it. Most likely in a way that you will not be able to recover from, spinning you around on the spot.
#359 | |
79-04 TRACK ADJ UPR CNTRL ARMSSPHERICAL ROD ENDS 1979-2004 - CJ Pony Parts, Inc. |
#360 | |
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks Last edited by ReverendDexter; April 2nd, 2010 at 09:20 PM. |
Threads Similar to: The Official Suspension Guide
| a/c removal guide? | dmac45 | 94-95 | 0 | June 5th, 2008 06:12 PM |
| install guide | 01silversnake | 99-04 | 1 | September 24th, 2007 09:05 AM |
| Guide To Building A 4.6 | man_of_war2081 | 99-04 | 7 | February 25th, 2007 06:40 PM |
| Funny Guide To Modification | thewayshemoves | The Clubhouse | 0 | December 24th, 2006 05:46 AM |
| 289 hi-po guide | 99mustang232 | Classic Mustangs | 6 | December 5th, 2006 11:33 AM |
