LinkBack (1) | Thread Tools |
#1
MM's Ford Truck Guy
99 ranger,2010 ranger
does nice burnouts
How to figure out compression...
ok this is the formula for finding out your compression ratio in your mustang if you dont know what it is. If your doin a build on your own and your doin boost you will want to do a lower compression such as 8.5:1 and if your doin a all motor build with nitrous personally i wouldnt go anything over 10:1 but that 1 is up to you.
If your doin a all motor build if you go anything over 12:1 you have 2 run a higher octane than 93 if you want it 2 run right. Just thought this could help some people out. Bore X Bore X .7854 X stroke= Cylinder Volume V1 Bore X Bore X .7854 X Deck Height= Deck Clearance Volume V2 Bore X Bore X .7854 X Head Gasket Thickness= Gasket Opening Volume V3 Comustion Chamber Volume in CC's(cubic centimeters) To Convert CC's to Cubic inches, Multiply CC's by .06102 CC's X .06102= V4 V1+V2+V3+V4 = COMPRESSION RATIO V2+V3+V4 REP IS ALWAYS WELCOMED
![]() 1999 xlt 2.5 ranger lowered 5/6 on 17in bullits 2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits |
Resident Bubblehead
nice. good info here...
i have no idea
dam nice, now did u get that out of u class books? reps to u anyways
![]() Silver Vehicle Club Member #2 MM Truck Crew Member #2 MODS LIST: Synthetic blinker fluid, Stg2 muffler bearings(cryo treated), Upgraded bumper bolts, computer reflashIII, 92hp shot of nitrous into the transmission(faster shifting and makes it 24/7 shifting fukkers!), Titanum locking oil drain plug(weight reduction), Spongebob harness(gotta be safe), Oil cooled air intake with a built in turbo simulator blow off valve, and a custom CANOOTER valve! |
MM's Ford Truck Guy
does nice burnouts
yeah i did get it out of my book from school but i learned it a while ago from a guy that has been building motors for 30 years he gave me the formula he is a master mind when it comes to building motors his shop's name is Action Auto Works of Stafford Va he is the best of the best for motors and transmissions he can build 1 sick transmission he built the one for our cobra and my mach 1
1989 GT
KB 2.1L Flowzilla
I'll say it again. It's still missing one important factor, piston head volume.
how did you get it out of your course one book..or out of the bad ass Tim Gilles book?.i mean...UTI doesnt teach a god damn thing duh remember? havent you heard that rumor
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
MM's Ford Truck Guy
does nice burnouts
yeah uti doesnt teach you anything lol
This is for static CR. There is also dynamic CR which is more useful.
Here is a calculator that factors for cam timing. You can run higher compression ratios if the cam has the proper overlap to bleed off enough compression. United Engine and Machine Co. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/92561-how-figure-out-compression.html
| How to figure out compression... | This thread | Refback | November 24th, 2008 02:02 AM | |
Threads Similar to: How to figure out compression...
| No one else can figure this out, but I know you can! | jkellam | 94-95 | 7 | October 8th, 2008 11:36 PM |
| How to figure out compression ratio. | FX4DTUF | The Clubhouse | 27 | September 7th, 2008 05:56 PM |
| go figure! | P.O.S-GT | 5.0 Mustangs | 3 | June 22nd, 2007 10:13 AM |
| Figure this out... | Foxstang90 | 5.0 Mustangs | 3 | February 18th, 2007 12:15 AM |
| Need Help... Cant Figure Out | mustangrebuilder | Classic Mustangs | 5 | September 6th, 2006 11:48 PM |
