2003 gt
low 13s
cam install
so im finally getting off my lazy ace and getting started with installing the cams i bought 2 years ago. the question i have for you guys is can i drive the car to the tuner when im done or do i have to tow it? there stage 2 comps and yes i am changing the springs as well. thanks for any pointers guys.
this is my signature |
N/A 4v Guru
2003 Mach 1
how far away is the tuner? for stage 2's you can "drive" it but its gonna have shitty driveability til its tuned. So if the tuner is just down the road then yes but if its a couple hundred miles then it's iffy.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2003 gt
low 13s
its not going to be a couple hundred but its most likely over 50, do you think maybe one of those handheld tuners can help a little with a specific tune downloaded? thanks for the info.
01 gt
holy shit two years ago, and i thought i was a procrastantor haha gl.
#5 | |
N/A 4v Guru
2003 Mach 1
Not unless it has a custom tune on it. I would just install them, take it for a little easy drive around and see how she acts. If it doesn't wanna run very well then just haul it to the tuner. actualy driving it will tell you whether or not its good to go or not
07 gt
+1 but be careful i have a buddy who destroyed his motor driving his car untuned after a heads/cams/stoker swap
07 GT 5spd Black on Black BBK Equal Length Shorties 4.10s FRPP K springs JLT with canned tune Pypes O/R H Pype Bomb axleback Steeda UDP |
1997 Mustang GT
Faster than an s4
Those stage 2's might have PTV issues. I would double check on that with the manufacturer before I dropped em in and tried to drive it.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
#8 | |
N/A 4v Guru
2003 Mach 1
+1 Yes I assumed he already knew how to degree them and if he needed to but if you don't mike then you need to find out from comp if you need to degree them. are they 270's?
2003 gt
low 13s
yes they are xe270ah
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I love the Comp 270's, but they have been a real pain to me at times. I had one pair that I couldn't get timed good enough to keep the valves off the pistons. I ended up having to notch the pistons. They are great cams, but just be careful on the install.
2003 gt
low 13s
i was reading up on the degree process and it seems like a pain but i guess its a must. i thought it was only for maximum power gains but i see now its a interferance issue as well. im starting to think these things are going to be sitting around for another 2 years haha.
hummmm well if you dont want them ill buy em from you lol. im lookin for some xe270ah's right now, and dont wanna spend the 600$ that americanmuscle wants for them, if your willin to let them go for 400 let me know......
1998 Mustang GT
1:34.43@13.86
get pi cams
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
2003 Mustang Cobra
GL. I love lopey cams on a muscle car
Rollin' 18/ pushin' 2
Wow, really? It's an 03 dude, PI cams are stock on his motor. You really earned your neg rep didn't you.
1998 GT Mustang
N/A
So how about this threads sorta old and got brought up for no reason...
![]() Pi Swapped, K&N CAI, Diablo Tune, BBk O/R X-Pipe with Flow's dumped and a 5.4L on its way. |
#18 | |
2001 Cobra
14.2@102 (I suck)
![]() so did you install them?
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Threads Similar to: cam install
| Cam install | usafimj | 2005 - 2010 | 35 | March 4th, 2010 07:01 PM |
| cam install? | Jucostud | 2005 - 2010 | 23 | October 12th, 2008 10:44 PM |
| Cam Install? | beastGT | 2005 - 2010 | 44 | August 29th, 2008 12:43 AM |
| Cam install ?'s | pfcbrook | 99-04 | 12 | February 29th, 2008 09:11 PM |
| cam install | 95blueGT | 94-95 | 4 | October 12th, 2007 02:56 AM |
