What is the difference if any...
between the below specs:
Work with stock valve springs. RPM Range 2500-5500. Noticeable idle. Tune suggested. Gains of 25-30rwhp. 540/550 lift, 224/226 .050" duration, 110 LSA --------------------------------------------------------- Cam Style: Hydraulic roller follower Basic Operating RPM Range: 1,400-5,400 RPM Intake Duration 050 inch Lift: 226 Exhaust Duration 050 inch Lift: 230 Duration at 050 inch Lift: 226 int./230 exh. Advertised Intake Duration: 262 Advertised Exhaust Duration: 266 Advertised Duration: 262 int./266 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.550 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 Valve Lift with Factory Rocker Arm Ratio: 0.550 int./0.550 exh. lift Lobe Separation (degrees): 113 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: Yes Grind Number: XE262AH-13 Quantity: Sold as a pair. Notes: Valve springs recommended. Designed to work with OEM performance improvement cylinder heads. |
Threads Similar to: What is the difference if any...
| Difference between S/Cs | RandoGT | General Tech | 13 | July 16th, 2007 02:52 PM |
| What is the difference between a GT 5.0 and GT 5.0 HO ? | robertbruder | 94-95 | 6 | June 28th, 2007 02:52 PM |
| What is the difference between these two? | energiesource | 99-04 | 2 | April 7th, 2007 03:53 PM |
| Any difference? | amphibrecon | 99-04 | 8 | March 30th, 2007 11:21 AM |
| Difference? | shroom | 99-04 | 12 | February 4th, 2007 12:33 PM |
