1989 Mustang GT
14.01 @ 103..... :(
Can u mess up a purge selenoid?
HEy me and my buddy put in a zex wet kit last nite in his 03 and we hooked up the purge to the twelve volt and switch and grounded it. it worked for a second then we couldnt get to open anymore. is there any stupid things we may have over looked ? and can we make a relay off the accessories post and run the switches off that if we use a fuse and stuff... ? thanks
![]() vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the purge solenoid is a small solenoid and dont need a relay. it works off 12+ and ground. make sure the wiring is good. if you need to double check, just jump the wires to see if it is doing what it should.
1989 Mustang GT
14.01 @ 103..... :(
we got it fixed it was just a bad ground. We were up till about 330 installing it so we weren't thinkin so clear.
Threads Similar to: Can u mess up a purge selenoid?
| did i mess up? | 00mustang00 | 99-04 | 11 | September 5th, 2008 02:26 AM |
| a little mess | Tr1gger | 5.0 Mustangs | 1 | February 18th, 2007 06:55 PM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 01:45 PM |
