Possible to install a 04 Cobra engine in a 99 base?
The title pretty much says it all. I'm curious if it would be possible to install a 2004 Cobra engine in a 1999 base. If it is, what would be involved, and what additional parts would be needed to be changed/added/removed.
The reason I ask is because I have the ability to pickup 2004 Cobra engine on the cheap, and I have friends that would be willing to do all the work and have access to all the tools to do something like this. Thanks. |
You can out the Cobra motor in. Depending on what you have will depend on what you will need. You will need a computer, wire harness, trans mount, maybe motor mounts. Not sure if you have to change out the pedal assembly or not. I am sure you will need more then that, but those are the basics.
2009 427R Vert 3.73's, Roush Big Brake Kit
Would there be any way to find out an exact list of what I would need?
You can try calling these Guy's. Prestige Mustang 404.294.4869
Threads Similar to: Possible to install a 04 Cobra engine in a 99 base?
| which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt | gtjason | New Members Introductions | 13 | March 1st, 2011 11:45 PM |
| Cloning A GT 500 From A V6 Base | v6hornet | 2005 - 2010 | 17 | December 5th, 2007 12:42 PM |
| Check engine light after steeda udp install | clmozesc | 2005 - 2010 | 4 | October 18th, 2007 06:30 PM |
| Engine ZEX install | CosmoRide | Multimedia | 7 | July 3rd, 2007 03:30 AM |
| shaker base assembly | musman | Classic Mustangs | 0 | March 11th, 2007 12:53 PM |
