LinkBack (3) | Thread Tools |
#1
1991 Ford Mustang LX
4.6 from a lincoln mark viii in a foxbody sway?
My friend offered me a 4.6 out of a 1993 lincoln mark viii for a couple hundred bucks. Id like to put it in my 91 5.0 but im not sure what all i would need, obviously a new manual trans from a newer mustang, but as far as computers go what would control this motor out of a car that only came in auto? help please before i buy it.
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters |
looking to buy sn95 5.0
a couple hundred bucks for a 4v motor? thats a steal for sure....may need custom PCM, but would be well worth it
#3 | |
Priest of the Car Gods
is it the same motor as the cobras? and what year cobra are u tlaking about
93-98 Mark VIII and 96-98 Cobras share nearly identical engines. There are a few differences, but wiring harness's are the same. Any 96-01 ECU will work just fine. To put the engine in a fox you'll need a tubular k-member from QA1 or AJE. Any Tremec T3550 or T3650, T45 or T56 will bolt up. A T5 can work too, but you'll need the bell housing from Lakewood to make it work. Ive done these swaps before so its no shy territory for me.
#6 | |
True, but theres been alot of clearance issues with long tube headers. The AJE and QA1 are the only ones ive used and seen that do not interfere with long tube headers.
Ah, good to know! Being in California, I don't think too much about LTs, as there's no way to make them smog legal.
#9 | |
![]() Cali emissions FTL!
this could be a pretty good swap for a fox
1997 Mustang Cobra
8.65@84mph
man that would be a sick Fox. You never see that swap or i dont.
It's uncommon enough that every one I know of has been the subject of a magazine article.
Ive seen plenty of mod motors swapped into foxes. Ive been part of, or done my own. A Mark 8 motor in a fox isnt new at all.
Hi I just had a couple questions on the 4.6 Lincoln motor I am using in my swap. I have a smog exempt vehicle 67 f-100. I have the motor and auto now and I was planning on getting a t-56 when it becomes available. My questions if you wouldnt mind.
Will I need an adapter to run a t-56 with this engine? Best headers to run. I have the 98 with the anti theft but I have the whole harness switch, key, shifter. ... should I run the factory harness and computer or will the pats theft be too difficult to get around. Basically I am overwellmed with wiring right now and not sure what I can eliminate for a critical path. If you have any recommendations on where to get diagrams etc I would appreciate it. Sorry for the long message Jason |
youll need the bellhousing and MAYBE fabricate space in the trans tunnel.
96 GT
93-95 mark viii engines aren't so great as they have weak valve springs.You'll also have clearance problems with 93 mark viii intake manifold on your Fox as the intake has rear mounted throttle body.You'll need 97-98 mark viii intake manifold or 96-98 cobra one.
No, you don't need an adapter.All trannys between 4.6 modular engines are interchangeable.You can put manual tranny out of any 4.6 mustang behind mark vii engine as the blocks are the same.I'm not sure about 3V 05+ mustangs but I think it will bolt-up too,05+ mustangs are using hydraulic clutches.96-99 cobras are using mark viii teksid blocks. |
I Bought A Running 94 Lincoln Mark Viii...i Started It Before I Bought It....the Trans Is Good It Pulls And The Fluid Looks Good It Hit A Gaurd Rail On The Right Side And The Air Suspension Messed Up...$650
I Went To Summit To Buy The Qa1 K Member For The Mod Motor And The Guy There Said The K Member Wouldnt Fit....but Someone Else Told Me The Stock K Member Out Of The 96-04 Mustangs Would Bolt To The Fox So I Am Lost... *****sorry For The Thread Jack But Didnt Thnik I Should Start A New One When Theres One Going****
'89 GT/COBRA 5.0 HO 5spd 14.6 @ 97MPH... U/D PULLIES AND OFF ROAD H/PIPE |
Im Gonna Swap The Trans And Harness And Everything For This... Is There Anything I Should Worry About Clearances, The Intake, Exhaust, What Do I Need To Buy Before I Pull This Out...
I Planed On Using The Radiator Out Of The Mark To Will This Work With The Electric Fans? Think Im Gonna Do Away With The A/c
Goblin qucik question Clutch for t-56
I am far along with my Markviii block (1998) and finally got my t-56. I am aware I need a 96 up GT flywheel but what clutch will work. Do I need a 10.5 11 inch etc. I just havent found a lot of information as only a few had the 4.6 and t-56. I doubt there is a difference but just in case I was looking at the Fidanza 2.1 as this is mostly a street driver. Any input of advice would be great Thank you.
Jason |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/98288-4-6-lincoln-mark-viii-foxbody-sway.html
| what needs to be done for a modular engine swap - Ford Mustang Forums | This thread | Refback | March 22nd, 2009 10:15 AM | |
| what needs to be done for a modular engine swap - Ford Mustang Forums | This thread | Refback | February 21st, 2009 02:14 AM | |
| what needs to be done for a modular engine swap - Ford Mustang Forums | This thread | Pingback | January 11th, 2009 03:10 AM | |
Threads Similar to: 4.6 from a lincoln mark viii in a foxbody sway?
| Will Lincoln Mark VIII block work on 1998 Cobra? | cobra98sd | 96-98 | 14 | December 27th, 2009 03:18 PM |
| Lincoln Mark VIII to 04 GT swap | Straits15204 | 99-04 | 7 | June 17th, 2008 05:04 AM |
| Lincoln Mark VIII 4.6 | MikeyS281 | 99-04 | 7 | June 12th, 2008 11:20 PM |
