another v6 to 4.6
so ive had a 2002 v6 the last few years and ive been recently looking into swapping a 4.6 2v. i can get the wiring harness, computer, and complete motor for about $600-$700 from a friend. i have a couple friends that would help me with the install. my question is, would it be worth it? im in college and wont be getting a new car for a while. my goals are to run a 2.6 kenne bell with about 20psi once i get forged internals. if possible, id like to see 600+ rwhp. let me know what you guys think.
Fashion Guru
if you're going to be spending that much money to make a car do all that, then just get a termie... supporting 20psi isn't gonna be cheap, thats for damn sure
97 Mustang GT
slower than the speed of smell
just get a 5.4 2v instead
Priest of the Car Gods
you'll spend more time and money doing this swap then just finding a GT in the first place.
It's not just the motor that's different. Spring rates, brakes, tranny, and rear end are all different; those pieces that you chose to not replace will either be weak points and need to be replaced later, or cause a safety issue. Motor swaps escalate quickly. Take what you think you're gonna spend money and timewise, double it, and you're in the ballpark of what it will be if everything goes right.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
#5 | |
#6 | |
I'm not criticizing what you're doing, just making sure you know what you're in for. So far you sound more grounded than the rest of the "I wanna swap my sixxer" crowd, so props to you for that.
#7 | |
now, if in you guys opinion, the 5.4 would cost about the same and produce a little more power let me know. i dont wanna be doing any custom fabrication. ill be doing the swap with the help of two friends. to some, this swap may seem out of the blue, but ive been thinking about something like this for quite some time. |
97 Mustang GT
the 5.4 is essentially just a stroked 4.6 and would require pretty much the same stuff as the 4.6. it would cost about the same as a 4.6 as far as i know and produce more power. also if you decide to go 5.4 and get tired of the power you ca always stroke it some more to a 6.2L!!!! now tell me do youFRAMlly think a 4.6 can hold up against a 6.2? i think not
#9 | |
97 Mustang GT
ok let me put it this way. i HAVE a 4.6 and i WANT a 5.4. make sense? im only going to spend like 10k hopefully on my full build. granted it will be over the years.
I have a 4.6 and I wanna keep it... DOCH V8 32v.
2001 BULLITT, 1986 SVO
32 Valve!!
97 Mustang GT
hahahaha tell ya guys what you can keep your 32 valve and ill take the 5.4 k? man i am so stoked now, i should be getting my new 5.4 hps intake manifold soon.
2001 Mustang GT
N/A
Just get a Cobra and upgrade the charger!
dude if you want to run 20 psi on a 2v...yea its very possible but a lot of work, better off geting a 4v or 5.4 2 or 4v setup...me i have 96 mustang thats a 6 and im gonna be buying an aftermarket block from mmr.....not sure 4.6 or 5.4 but its the monster mod...yea i havce to buy the heads cams all that seperately, but im also redoing the entire car from top to bottom.....mine will be worth it, but just doin the engine swap.....take the advice on here, but its all uip to you man......
#16 | |
whats a DOCH V8?
Anywho, good luck with this build man. Sounds like your going to be completely redoing your entire car. I would have suggested going with a 4v matched up to that 6 speed. Its a much more practicle platform to try to get 600 hp. But to each his own.
![]() Last edited by 04mustang232; December 28th, 2008 at 11:27 PM. |
i say if ur gonna spend 20 grand buy a 04 cobra in the first place
Bearer of Bad News
I has mustang and legacy.
Slower than my Ruger.
Romeo 605.
Oh, and if you drop in that motor, do you have the manifolds, midpipe, and exhaust all ready to go as well?
~MOD NUTSWINGER~ My Tongue Soothes Razorburn ![]() STOPSAYINGFAIL.COM EVERY FART IS A GAMBLE Just Think Of Me As A White Blood Cell.
another dahm ford
as well as everything to swap from vacume to hydroboost brake system. that is what ate my bank account when i swapped from 3.8 to 4.6
