Engine ZEX install |
and this is a wet system? how easy was the install?
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
#3 | |
You hook up the bottle in the trunk then the main unit by the MAF which you can see in the picture , then you hook up an Addapter that you get with the kit to your right side fuel rail....you just replace the bolt with the addapter and that's it .....the only thing left is running the nitrous line from the trunk to the main unit , then from the fuel rail to the main unit . and then both nitrous and fuel from the main unit into the nozzel , hooking up Ground wire ,positive, and TPS wire and you are ready to go ****EDIT****** YES it's a wet system , the way you can tell is there are two lines running into the nozzel in the CAI if it was one then it'd be a dry kit ....WET is called wet since there is a mixture of fuel and nitrous being sprayed..that way you dont run to lean....also the ZEX main unit makes sure that you dont run to rich or to lean...let's say for some reason one of your fuel injectors doesnt work and you dont know ...and you are about to spray....the ZEX main unit will actually detect that you are running to lean and will not let you spray...preventing engine damadge ;-) The only other kit that has something like that is Venom ...but it is way to expensive |
well if i end up buying this from you i may have to offer you a few brews to come over and supervise my install
#5 | |
But if you'd like you could drive up one day and I'd be more then happy to help you out . Or if you'd like I could make an Video install guide for you so that you can do it yourself...trust me is very easy....the hardest part about it is tapping into the TPS wire (which is very easy lol ) ****EDIT**** Installing the MSD Digital window switch would require you to tap into the rpm wire which is behind the tech...and I took it to a shop to get that done $50 spent on that ! ! ! DIdnt wanna mess with that |
ha ha ha nah i was kidding about getting you down here, i'm sure i can handle it, i've done worse.... =)
i'm actually going to be in Madiera beach for the whole first week of July... Vacation time thank god. it will take me a few weeks to get up the cash for the purchase, but i am definitly interested... there is no tune required to get it done?
#7 | |
I was in Naples today :-) Exit 107 all the way down to 9th st ..then left and then right on 4th avenue ....was taking some blood to NTH Hospital Yeah , NP with the money man.....I have the kit here.... |
SOLD THE KIT TODAY !!!
Threads Similar to: Engine ZEX install
| Engine Build Up or Engine Replacement... | OcOnnor220 | 99-04 | 8 | July 27th, 2008 04:54 PM |
| Check engine light after steeda udp install | clmozesc | 2005 - 2010 | 4 | October 18th, 2007 06:30 PM |
| 1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? | zygo4406 | 5.0 Mustangs | 10 | June 4th, 2007 06:53 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 06:09 PM |
| Possible to install a 04 Cobra engine in a 99 base? | HypeTelecon | Modular Mustangs | 3 | December 19th, 2006 09:11 PM |
