Look Ma! My First Post!
Heat issues mustang ii 1977 302
i have a 1977 mustang ii 302 stroker (342) aprox 370HP, C4 trans 3.80 aulburn posi. the car water temp runs 220 - 240 degrees. i have the stock replacement radiator with 16" electric fan, thermostat is 180 degree. I have even put in the cooler liquid that says will cool a engine down. motor has about 500 miles on it. Thanks
1966 Mustang Convertible
How do you have you fan set up, temp control or run all the time. If temp control try dropping the set point and maybe a lower degree thermostat.
Dare to Differ: STAY INLINE 1966 Mustang convertible, candyapple red, black power top, black interior, auto trans, autolite 1100 carb, Pertronix Ignitor, Scarebird 4 lug disc brake conversion, duel master cylinder. 1976 Cobra II |
#3 | |
does it have air in it? if it does it could be in the cooling system.
If it's heating up like that it could very well lead to engine damage,blown head Gasket etc. Don't want that,try flushing out the system and use a good quality coolant system cleaner. |
2007 G9 Eye Catcher
Too small of radiator??? The OE size ones were pretty small. Which would equal insufficient flow like 1slo5.0 mentioned.
Threads Similar to: Heat issues mustang ii 1977 302
| 1966 mustang steering issues | rjlope66gt | Classic Mustangs | 5 | April 3rd, 2008 06:38 PM |
| My Mustang Has Issues! Need Advice... Thanks! | Mrs_Mustang | V6 Mustangs | 5 | November 12th, 2007 10:39 AM |
| How to Get Laid in 1977 and Your Ass Kicked in 2007 | vfast | The Clubhouse | 3 | November 1st, 2007 12:47 AM |
| 1989 Mustang questions and issues | FranMan | 5.0 Mustangs | 10 | August 8th, 2007 07:05 PM |
| 1995 Mustang V6 temperature issues | I_CTCHR95 | V6 Mustangs | 1 | November 5th, 2006 10:43 AM |
