1976 Mustang II Beef Project Help
Go Back   Forums at Modded Mustangs > Mustang Forums > Classic Mustangs > Mustang II
Old November 26th, 2007, 05:30 PM   #1
Look Ma! My First Post!
raininrandall is on a distinguished road
Smile
I am the proud owner of a 1976 Mustang II Cobra wit ha 171 cid, 2.8L V6. I am trying to find products to "beef it up." Any help and/or recommendations from experienced people is welcome. I am new to this generation of Mustang, so be prepared to answer a lot of stupid questions that I will undoubtedly ask. Please put all responses in the simplest form so I can understand it. Thanks for your help
Old November 26th, 2007, 05:33 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
I moved this thread for you since the v6 section is for the 1994+ v6 mustangs, and you are more likely to see responses here.
Welcome to ModdedMustangs!
ModdedAutos
1999 Mustang V6
Old November 26th, 2007, 06:01 PM   #3
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
if you're not against changing out the engine then go with that.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old December 30th, 2007, 12:42 PM   #4
spec_mize is on a distinguished road
Send a message via AIM to spec_mize Send a message via Yahoo to spec_mize
yes the 302 or 351 will mount in place with no problem. i dont think you even have to change the wire harness. be careful in doing this however. the mustangii is so light that it is easy to pull the front end off the ground. if you go with a stock 302 dont go bigger than a 650cfm 4 bbl otherwise youll flood the valves.
Old December 30th, 2007, 07:52 PM   #5
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
does it have the stock 4 speed?....or is it automatic?
i would swap it over for a 5.0, you can make more power easier with less money, and they are pretty popular so finding anything for them is simple
you can pull a harness out of a v8 one for a few bucks, then get different motor mounts and you should be set
but welcome to the mustang II community (its a small community on this fourm)
Old January 6th, 2008, 07:58 AM   #6
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
It may be small, but its growing. You can help it grow by letting other Mustang II's owners know about us.
Classic Mustangs are the best! Get one.
Old January 6th, 2008, 07:31 PM   #7
78mach1's Avatar
hey you horseshoeing, what do you drive?
Old January 7th, 2008, 07:48 PM   #8
Fez
'03 GT convertible
Fez is on a distinguished road
I put a 5.0 HO in my '75 Ghia back in the 80's. Sure made for a different car! I was tired of being beaten by Hona preludes and the like, it never happened again! Do you have the experience to make this swap. It is relatively easy but parts may be harder to find used and it was a tight fit even by the factory. You may also have to consider any emissions laws in your state.
Old January 7th, 2008, 11:33 PM   #9
78mach1's Avatar
mustang II`s (like mine) came with a 5.0 in it........its not a tight fit......
Old January 10th, 2008, 01:31 AM   #10
Blue_coyote's Avatar
Mustang II fanatic
Blue_coyote is on a distinguished road
While not usually cheap, the Cologne V6 as used in the II CAN be a fun little bugger.
The one I have pushes more HP than any of the 302's Ford put in a II
Offenhauser made a decent 4bbl intake, they came from the factory with solid lifters and gear driven timing, and a quality rebuild can net you at least 200 reliable HP and a redline in the 7500 RPM range. The only reliability issues I've run into with 2.8's over the years are the dreaded oil seepage and keeping head gaskets from blowing out after long-term abuse
When I ran that engine in my old Bronco II it was kinda fun spanking Fast & Furious ricer wannabe's in a V6 powered chop top, thoroughly rednecked trail pig on 32" mudders...
78 King black on black T-top (the "Rat Snake" )
78 T-top V8toV6 upgrade project
74 Avocado Ghia
Old September 16th, 2008, 06:07 PM   #11
stang74shelby is on a distinguished road
Cool
2.8
Well if u have access, the europeans made a 2.8 turbo V-6 and a 3.0 turbo V-6 for the Ford Sierra (Merkur xr4ti) and the Ford Capri..... so u can get lots of power from a 6, had a friend with a turbo 2.8 pushing 450 horse in a sierra (cosworth clone)
Threads Similar to: 1976 Mustang II Beef Project Help
1976 ford mustang II Help Quick stang94 5.0 Mustangs 5 June 21st, 2007 11:16 PM
Best FORD project car to get? (non-mustang) nba1341 All Other Vehicles 32 April 30th, 2007 12:54 PM
5.0 Beef up...suggestions? 95blackbeauty 5.0 Mustangs 9 March 9th, 2007 04:47 PM
