#41 |
thanx all
and i got most stuff from local forums and stores. also got the BOV and wastegate from cxracing.com. Got the piping/clamps/bung/silicone couplers from racepartsolution.com and its almost done. just two more things to do and then we gonna start it up
![]() 1995 Turbo V6 Mustang (auto) Check out my build <---- ET: 14.1@99mph (coupler blowing off/MBC failing ) Built by Iron Horse Motorsports |
#42 |
almost done, just need to tap into the oil pan and put the rest of the misc stuff back on.
#43 |
Bringing Yellow Back
looking good bro
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
#44 |
thank u sir
#45 |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
Grats! Looking good. Keep us posted. What are you going to use to tune her?
#46 |
i want you to take this to the track ASAP
#47 |
you should sell these kits to the guys here on mm
#48 | |
sure will ![]() that would be cool but im not building this kit. Its being fab up by Iron Horse Motorsports here is there web site http://www.teamironhorse.com/
#49 |
Almost ready to start her up, next update will be a vid
#50 |
Its been what? almost a year since ive updated...
![]() Well i drove her with for about 7 months with the turbo on (running 12psi) And she finally decided to give around January. But i did run her at the track and got a best of 14.1@99mph with coupler blowing off and MBC missing up. Here is a video of me at the track... Was running 12psi and the stock replacement piston decided to give (sealed power pistons) Looks like piston #6 was the only one messed up. These pistons are know to crack like that You could see it has cracks on the left and right side of the piston. If I would have driven it for a little bit longer, the whole damn piston would have broke ![]() This was from another V6 mustang with the same pistons as me and that also had a power adder ![]() But here is whats being installed Comp Turbo Cam/Springs 4.3L stroker, 4.2L crank,351W SCAT H-Beam Rods, custom forged pistons 3200 Stall Converter Granatelli K-Member Lower tubular A-arms super sport coil over (Red) springs 14.5 # wastegate spring
#51 |
I re-painted my block ford blue and installed the cam
![]() Also, I sort of polished my turbo housing and heads....I still need to use that aluminum polish stuff to finish it off. I used 180 grid first and finished with 1500 grid sandpaper. ![]() ![]() ![]() ![]() ![]()
#52 |
Just wanted to see how the heads would look on the block
#53 |
got the pistons in yesterday...
Threads Similar to: Going to boost my 6
| How Much Boost??? | 330CubeGt | 96-98 | 52 | April 2nd, 2009 12:21 AM |
| how much boost | stangdriven | 4V / SVT | 2 | March 27th, 2009 02:08 PM |
| how much boost??? | droppedbass87 | 96-98 | 4 | June 23rd, 2007 02:18 PM |
| how much boost??? | 9stang1 | 5.0 Mustangs | 5 | December 5th, 2006 05:32 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
