1997 Mustang Cobra
11.87@115.97
E85 sucks!!
Just Kidding!
lolWe finally got around to converting my car to E85. woop woop! lol We started everything off with a base pull. Pulled the car into the shop, let it sit for MAYBE an hour (had to go grab a couple jugs of E85 lol), then threw it on the dyno to see what it makes. Specs: 1997 Cobra ~Stock 97 Cobra 4v B heads, stock upper and lower intake, stock cams. ~2003 GT shortblock, stock GT pistons, stock GT rods, stock GT crank. ~61mm Precision T4 turbo, custom turbo kit built by Power By The Hour. ~38lb/hr Lucas Injectors, 255 in tank and 255 in line fuel pumps, -8 feed -6 return. ~Boost is straight off the wastegate spring, so average of 9.5-10.5psi throughout the run. Outdoor air temp: 95*F Outdoor humidity: 42% ![]() We then swapped the injectors out for a set of High Impedance Siemens Deka 80lb/hr. When Ken originally tuned the car for the turbo with gas and the smaller lucas injectors, he had to adjust the mass air curve for the a/f to be correct (the 38lb injectors are a GM injectors and spray less than an actual 38lb injector would). So with that being said, we didn't get a completely accurate gas vs. e85 WITH the same timing and mass air curve. But with everything corrected, timing added, a/f adjusted to see an average of about 11.8 WOT, this is what the car ended up making: Same specs as before, but with 80lb injectors. Outdoor air temp: 95*F Outdoor humidity: 50% ![]() And here is just a graph of the E85 pull and gas pull together: ![]() Dyno Video: If anyone has any questions, feel free to ask away!
Bringing Yellow Back
great job!
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
1997 Mustang Cobra
11.87@115.97
Thanks! Definitely super happy with the outcome.
Nice numbers!!!
Sounds very healthy!! that's awesome to drive i guess!!! good job!!
Dark Shadow Gray 1 mod or 2 ![]() Thanks to Sarah for the Sig!! ![]() http://www.moddedmustangs.com/forums...-member-35708/ MM DSG Crew Member#3 |
#5 | |
1997 Mustang Cobra
11.87@115.97
Seems like she's picked up a little bit of a deeper tone with the newfound power...I like it. lol
Authorized Vendor
![]() Join Date: Feb 2009
That is awesome Danielle!
You may influence my choice in fuel on mine.
Kelly Aiken "The Ford Guy" BMR Suspension Inc kelly@bmrsuspension.com 813.986.9302 CLICK IF YOU LIKE BMR SUSPENSION |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
Good stuff! Wish the stations around here had actual E85 and not E70. I'm going to be forced to run Meth instead
. Either that or mix my own, which is not worth it in a street car.Love your car! I hope to have some vid's up of a similar car soon. |
I Poop Entirely Way Too Much
Blown 03 GT
Not bad
sounds like a jet, I have been always jealous of your car lol
.............................2000 GT Vert............................. ![]() How To Cut/Remove springs |
Nice numbers man. I love your car as well.
2000 Mustang GT. Accufab Throttle body & plenum, CAI, BBK fuel rail, Steeda UnderDrive Pulley, Flowmaster 40's, Steeda Tri-ax Shifter ![]() |
Better than ONLYaUNCfan's
2012@lightspeed
Formerly, AhobosCheese and Cheddars.
Threads Similar to: E85 sucks!!
| This sucks | AMmuslGT | The Clubhouse | 21 | September 13th, 2009 05:16 PM |
| Having the flu sucks | White99stang | The Clubhouse | 8 | February 25th, 2009 05:19 PM |
| bad day at the track (I suck, SCT sucks and cold weather sucks) | 01GT4.6 | 99-04 | 18 | January 12th, 2009 09:08 PM |
| Sucks... | 02MustangV6e9 | The Clubhouse | 5 | August 13th, 2008 03:27 PM |
