Go Back   Forums at Modded Mustangs > Mustang Forums > General Tech > Power Adders
Discussing twin turbo ate a piston!! in the Power Adders Forum. Hey guys built a twin turbo setup for my 96 gt, had it running for ...
Old June 10th, 2009, 10:44 AM   #1
keiken's Avatar
Hey guys built a twin turbo setup for my 96 gt, had it running for a while at 8psi on everything stock and i ended up cracking 2 pistons and breaking one all 3 around the ring lands, no damage has been done to the block or heads and it looks like all i need is pistons. question is, can i go with another set of hypeuretic's or do i need to go forged, i never plan on going more then 400rwhp if i get it there, and the problem is im not working right now and i dont have much i can spend on her, but she is my DD so i cant be without her for long. what do you guys think, dished hypers ok>? im in b.c canada so forged is about 1100 to get and have shipped thanks
Old June 10th, 2009, 10:55 AM   #2
Blown 03 GT
IF you dont get forged your likely to break pistons again. Did the ring lands brake off or just crack? If the broke off your gonna want to get the heads checked. It would be very possible for a piece to get into the heads and do damage.
5L Livernois stroker with a Novi 2000 feedin 14 psi.
Originally Posted by MamaStang View Post
Turn her over if you don't like her breath.
Old June 10th, 2009, 11:07 AM   #3
keiken's Avatar
everything is good, the pistons cracked in between the lands, the broken part was also in between the lands but in the cylinders couldnt come out, theres no peices missing. ive heard lots of guys on her talking about running 10lbs on stock engines, am i just an unlucky happening or are they b.s? difference from forged and hypers here are over $600 so..thats why im trying to get away with hypers.....
Old June 10th, 2009, 12:11 PM   #4
Trick Tuners's Avatar
KB'd GT
Get your tuned fixed and you wont blow up pistons at only 8psi.
Detonation Explained
Old June 10th, 2009, 11:44 PM   #5
keiken's Avatar
ok, i'll get her built and take it to the tuners again, i thought it was kinda odd it failed so abrubtly, thanks for the help guys, do i need anyhting to tune it for 8-10 pounds or will everything handle that?(mass air,injectors,etc)
Old June 11th, 2009, 10:44 AM   #6
Blown 03 GT
Everythin should be good, but youll def be pushing the limits.
Old June 11th, 2009, 11:35 AM   #7
KB'd GT
Are you still using the stock maf and injectors?
Old June 12th, 2009, 01:02 AM   #8
keiken's Avatar
yeah stock maf and injectors, can a shop tune with those to handle 8 psi? or do i need at leaast a new maf? im only wanting to push around 350 rwhp right now
Old June 12th, 2009, 09:50 AM   #9
Blown 03 GT
The stock MAF will be fine, you injectors should work fine but they will definately be at their upper limits, I would replace them to be safe. Actually they are easy enough, that you can just have your tuner replace them if fuels is low when he tunes it.
Old June 12th, 2009, 12:05 PM   #10
KB'd GT
Upgrade everything. Fuel pump, injectors (to 60s because they cost the same) or the 39# cobra, because there are lots of used sets around. Get a new maf too (90mm Lmaf). Chances are everything is pegged and you went lean and thats why you have a hurt motor. the tuner should never have tuned your setup like this. If someone came to me with stock parts and 8psi (~50% increase in power) i'd tell them to come back when they had the right parts. I don't hack job tune because the customer is too cheap to buy the right parts. Its too risky.
Old June 13th, 2009, 08:32 PM   #11
keiken's Avatar
alright i guess i'll take it to the tuners and get it set for maybe 5 psi for now, then i got some shopping to do before i head to the tuners for more boost thanks for the help guys.
Threads Similar to: twin turbo ate a piston!!
STS Twin Turbo, turbo size? Redrocket06 2005 - 2009 9 January 26th, 2009 06:50 AM
Turbo HorsePower Twin Turbo kit dblindberg 2005 - 2009 34 June 17th, 2007 08:05 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Turbo, Twin Turbo, Procharger, or Kennebell? black94gt 5.0 Mustangs 19 October 7th, 2006 10:41 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2009 9 September 17th, 2006 04:15 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
