Discussing how hard to install supercharger in the Power Adders Forum. Looking into a vortech supercharger for my 02 mustang gt... How hard will it be ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
not sure yet :-(
Looking into a vortech supercharger for my 02 mustang gt... How hard will it be to install? Its a non intercooled setup..something I could do myself at the house?
2000 gt
you can easily do it at your house. hardest part is likely tapping the oil pan or doing the fuel pump. the other stuff is bolt on.
Procharged 2000 5 Speed BAB GT, 7.3 lbs, 368 hp, 406 rwtq.HARDCORE CREW |
not sure yet :-(
I was wandering...so that I don't have to drill my pan...could I like...say..put its own oil set up? Like its own like 2qt system or something?
1989 GT
KB 2.1L Flowzilla
Get a V3 kit. It's internally lubricated, no need to tap in to the oil pan.
not sure yet :-(
I would if I had the extra money ...but could I do that? That way it doesn't have the motors dirty possibly contaminated oil? And more oil than a slef lubricated so hopefuly it runs cooler too
~C~, The Other White Meat!
Y2K YellowJacket GT
~TBD~
I guess you could do it. I think it would be harder trying to make sure it would work right and finding a location to put it all. Take a look at the p1sc.
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
not sure yet :-(
Well as much as I wish I could afford procharger I can't... That's the one I really really want lol...but I mean me giving it its own oiling system would be the best thing...I mean the supercharger sucks the oil from the engines pan...I'd be giving it its own pan... And wouldn't be risking getting metal shavings in my motors oil from drilling the holes
2000 gt
you could do that, it would be a mess mounting it and getting a pump and all that for it. tapping the pan isn't that bad and if it were something dangerous they would have made a self contained one long before the v3. there are thousands of vortech's out there, i doubt if it were a big issue they would continue to make them.
prochargers can be foundpretty cheaply anyways if you look. i got my whole setup for $1400
Blown 03 GT
Tapping the pan isnt bad, just make sure you have a conical bit cuz the pan is this a regular bit doesnt work. I know I tried it and almost fucked up my pan! The return line isnt under alot of pressure is you dont have to worry bout it too much. I just drilled mine out and tapped it, i didnt even roll it in at all and it worked great! I got a nice snugs fit with the fitting screwed in.
Authorized Vendor
![]() 04 GT Coupe/87 GT T-Top
The Vortech V2 Kits (where you have to tap the oil pan) and the Vortech V3 Kits (where they are self lubricating) are actually the same price.
![]() Give us a call at BMC Performance if you have any questions we would love to help you, easy install that can be done at your house 1-877-BMC-RWHP
not sure yet :-(
Well not on ebay it aint...the v2 kit I'm looking at is like...2500 or so and comes with everything
#12 | |
1989 GT
KB 2.1L Flowzilla
Oil is fed to the s/c by engine oil pump. To make a separate oil system for the s/c you'd need an electric oil pump to circulate the oil.
not sure yet :-(
Really? How in the gell does it do that? If the lines are just plumbed into the side of the pan...I could see I it were sum how plumbed into a oil galley on the block
02 mustang gt
7.83 at 90 mph
the only issue with mine is the return leaks a little bit i had to seal it with jb weld and that seem to do the job but if you can get the v-3 and the loud s/c is cool sounding...
http://videos.streetfire.net/video/W...-vs_714149.htm 7.89 at 88.9 http://videos.streetfire.net/video/W...2gt_708085.htm KB lightning |
Blown 03 GT
the oil feed line connect to and extra tap on the oil filter housing.
not sure yet :-(
I don't know why but this thing doesn't always show me all yalls post like I didn't see mustanginkys post bout finding one for 1400...where in the hell did you find that steal lol that's sweet... And ahhh ok that makes a lot of since lol thanks for clearing that up on the oil feed...
you "could" rig up a standalone oil system but is it really worth the R&D and risk of it not working!? Get a cheap kit -> rig an oil system -> burn up the kit -> start all over. In the long run it could cost you more headache and $$$
Wait a bit more and save a few more bucks then go with a good tested design.
![]() 2002 Sonic Blue GT : Manual, FRPP 3.73's, Ram HDX Clutch, Pypes Violator Cat-Back, Pypes catted X-Pipe, Mach1 Chin, SCT Livewire, PLX SM-AFR as Analog input to LW |
I don't know of a lot of shops that would install a non-intercooled set up. Most guys want the intercooled version. Much safer.
Blown 03 GT
IF your just doin a bolt on system with 8 psi there is no need for an intercooler, Yeah it WOULD be better but you wont have an issue without one. This is why EVERY manufacturer sells non-intercooler base kits.
2001 bullitt #835
not fast enough
i completed my entire install in 2 days, drinking beer and taking my time. no problem at all if you got basic tools. the only thing you'll have to buy is a big enough tap for the oil pan, other than that its basic. peace!
Bullitt #835 4:10s, bbk O/R X, bassani mufflers, v1 vortech supercharger 12#boost
Threads Similar to: how hard to install supercharger
| how hard are headers to install | joohnn98 | 96-98 | 17 | March 15th, 2009 05:06 PM |
| how hard to install 5.4l svt | dieselboy79 | Classic Mustangs | 24 | March 8th, 2009 03:09 PM |
| how hard will this install be... | texas_mustang | 2005+ | 47 | May 27th, 2008 09:27 AM |
| How hard of an install?? | AnglicoGT98 | 99-04 | 14 | January 24th, 2008 11:37 PM |
| Is a CAI hard to install? | Compy386 | V6 Mustangs | 19 | January 30th, 2007 05:20 AM |
