Discussing Lets Talk Boost... in the Power Adders Forum. Originally Posted by slownomo TURBO= coked up engine parts and extreme under hood temps.. not ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 | |
V-SICKS
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
![]() The Devil & The Daily Daily-13.37@104.4mph V6- Stock bottom-439rwhp & 402rwtq 12psi 100oct built motor-497rwhp & 508rwtq 15psi pump |
#42 | |
V-SICKS
00 V6 & 09 GT
s/c is by far the worst dd power adder out there i can hit 5000rpms with out hitting 1psi in my car. so shut up and quit giving out miss information i can drive the rest of my life in my turbo stang and never once hit boost lol then 2-4k the boost came on like crazy and wheels spun? last time i checked that wasnt a bad thing. just meant you have shitty suspensionbut then between 2-5k you say s/c blow away turbos? ![]() where the fuck did you get that?! the only s/c that stands a chance are twin screws and ONLY off the line. turbos ALWAYS ALWAYS murder on the top end thats what they're best at. for example supra vs cobra races ALMOST EVERY race the supra is losing on the jump killing at the end. at most if a cobra wins its either nitrous or he gets the jump and keeps a distance. never pulling you've got it completely the opposite way you cant compare you VIDEO watching experience to real life i've driven all 3 CLEARLY turbo is by far the best way to go. if honda's NEVER almost go s/c despite they're DESPRATE NEED for low end torque they go turbo your the first person ive ever heard to say a s/c will shine and take over at higher rpms then a s/c all of the worlds fastest cars a turbo'd NONE are s/c and they dont even really come close the more power you make with a s/c the more power your also LOSING explain this a fellow v6 mustang owner first to make 500rwhp off a vortech made 500 and claimed he was losing well over 100RWHP just from having the s/c.THATS A 100RWHP hes now turbo'd making 640rwhp SAE with just 17psi perfect other example twin turbo v6 mustang made 611rwhp off 16psi pump gas, 19in rims auto built tranny s/c (procharged) V6 mustang SAME motor higher compression, same auto tranny, smaller rims on 18psi made only 495rwhp!!!! NOT ONLY is he making 116rwhp LESS on VERY similar setups but his compression is HIGHER, and he's running 2psi MORE. throw 18psi on the twin turbo mustang your seeing 650+rwhp turbos are MUCH more forgiving to a motor then a s/c turbos make MUCH more power then s/c at the same boost turbo's with low boost generally can run 3-4psi LESS then a s/c and make similar power at HIGH hp levels and boost levels the s/c gets worst, as i just explained a turbo could have run at about 11psi and made what a 18psi s/c made... turbo's are easier to maintain more money for the hp easier to turn up boost better mpg honestly the only true PLUS to a s/c is the ease of installing it. aside from that there is nothing else better about it you can say price but ive seen turbo kits CHEAPER then s/ckits
#43 | |
83 Mustang GT-Twin Turbo
10.82@126
As was said its all about expereinces and preferrences but if you need a race against yours or anyones!!! Twin screw Car I am sure there is more than a few that can handle that ass woopin. How many 8sec TwinScrew cars are there. How about 9 sec?? Now how many Turbo cars. I mean come on you cant add a blower to a mildy built honda and run 11s but you can put a turbo and they run good for a little 4 banger!!
BOOST!!! The replacement for displacement!!
#44 | |
2004 Mach 1 -Pro Charger
I have both and the super charger is much better related to low end power and over all performance. There will be those the have a different opinion I am sure. If want want a pure track car the turbos are ok. On the street they are just not as good...
2007 Dodge SRT-8 Superbee 2007 Hemi Quad Cab 4X4 2004 Ford MACH I Mustang, Pro-Charger 535 RWHP 2002 Viper SRT-10 575RWHP, 1985 Mustang GT 1992 Stealth RT TT 633.9 AWHP 1992 Stealth RT
#45 |
01 nitrous injected GT
12s next time out...
turbos help gas mileage
#46 |
10.82@126
oh and when comparing prices from s/c to turbo make sure you add in headers for the s/c cars and h/x pipe, and a cold air intake system for those twinscrew(roots style). And belts and extra pullies for turning up the boost.
Example a KB or Whipple for the mod 2v or na 4v is about 3800 give or take depending on the deal and size. Plus to move the new found air into motor you are going to need long tubes about500-800, and an x/h pipe about300. Now a single turbo kit complete is right at 4200( same give or take for deal size and manf.) But you are done. Both are going to need more fuel delivery( injectors and pump) and tunes. 03-04 cobra same prices up or down a little for the blowers. Again you'll need headers,x/h, cold air, fuel, tune complete kits with intakes are around 6000 but most of those kits also come with tubular k-members also. We wont even get into the Centrifugal S/C
#47 |
OK if you say so - but not in my 633AWHP Dodge Stealth. (pump gas). Also depending on the type of turbos you get your spool up time will differ. If you get some large enough to carry high CFM and boost then you better have the displacement to spin them up. Turbo lag is very common with after market turbo set ups.
#48 | |
#49 | |
10.82@126
And last I checked you needed to change you oil evey 3000 miles anyway. but yes it is harder on the oil. Also when I dont have my foot in it it drives and gets mileage better than a stock car. There is no constant drag on the motor. And I am sure my car makes power at a faster ramp rate than yours. Thats not a "mines BIGGER" type of statement. I mean that the ramp rate of power increase starts sooner, comes on faster, and stays for longer than your car. Turbo cars have more range of peek power that is the main reason they are faster. My pushrod motor to your Modular motor is not the best example but it has the same point!! If you make 450 rwhp then add an average of 20% drag for the blower. So just think of the power at the same boost and intake temps that would be without the added drag and wear.
#50 | |
10.82@126
the 10s are with the single turbo set-up. Oh and that is as always with 17inch DR and road-race style suspension. Its a street car not a drag wagon. I could personally care less what it does in the quarter. I have a Drag car this is just a street car for fun!!!!!
#51 |
How long has it been since anyone has looked at pricing? A Hellion Single starts at $5995.00 and ad about $1700.00 for K-member, ball bearing, a little larger turbo etc. The KB with all the bells and whistles including intercooler and 8 rib system is $7400.00 with a 2.3L. Whipples come in around $6500.00 when all is said and done.
Its all subjective. Some guys are "light to light", and for that instant on is perfect so go hybrid roots or twin screw. At the track either system will work, but the positive displacement guys always come out of the box first, while the turbo and centrifugal play "catch up". Then for the REAL SERIOUS guys...top fuel, funny car, we are back to belt driven positive displacement blowers. |
#52 |
10.82@126
I have raced quite a few cobras with KB from a dig and they didn't "come on" anyfaster than I did!! But like was said its peas to carrots. They both work with fantastic results!! But I will stand by the turbo over blower
#53 |
Which are the peas and which are the carrots. LOL. A friend and I just completed the design of a supercharger kit for the 99-04 GT daily driver guys. Low cost, positive displacement, Magnuson based. You seem to have been around...what do you think.
![]() This was on a absolutely bone stock 99 GT that was done for a customer. |
#54 | ||
~C~, The Other White Meat!
Y2K YellowJacket GT
~TBD~
Fuck! Does anyone want to buy a procharger!??!?
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
#55 | |
10.82@126
#56 |
we should make this a poll and see which one people like more...unless thats already been done...
2000 AUTO GT (TOTALED): 17 inch anthracite bullit wheels (apparently 05+'s), chin spoiler and grill delete, tint. flowmaster 40 weld ons, sct x3 (FOR SALE!!!), 1.5" drop, 1" wheel spacers, and 4.10's (most of this stuff is ruined) |
Threads Similar to: Lets Talk Boost...
| Lets talk about interesting stories with girls our cars made | Cricket | The Clubhouse | 27 | September 30th, 2007 05:43 PM |
| lets talk gas mileage | usedhippo | V6 Mustangs | 24 | June 12th, 2007 05:56 PM |
| Lets Talk Classic Rock | Drick | The Clubhouse | 13 | June 2nd, 2007 12:50 PM |
| lets talk rap tony | MSO | The Clubhouse | 101 | May 7th, 2007 09:51 PM |
| Turbo Boost vs Super Boost | droppedbass87 | Power Adders | 12 | October 16th, 2006 10:56 AM |
