Discussing Nitrous??? in the Power Adders Forum. I am thinking about putting a little bit of juice on my 1987 Mustang LX ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Nitrous???
I am thinking about putting a little bit of juice on my 1987 Mustang LX 5.0 AOD. I was wondering if anyone had some good suggestions for what brand, jet size, etc. to get. The only modifications I plan on doing are cold air intake, TrickFlow upper and lower intake manifolds, BBK or maybe Hooker Longtubes, a Flowmaster Cat-back, and possibly a 70 MM throttle body. Anyone know what I should do as far as nitrous goes or possibly even changing/adding anything to my "wish list". Also I kind of don't want to give it away that I have spray when you look under the hood.
mm's nitrous mod
2000 mustang gt
11.79@115.83
a plate system will probably be a little easies to hide. really it is where you decide to install everything, to the way it looks.
right now, she is a jackstand warrior if the car was a horse, i would shoot it!!! ![]() project warhorse under construction being built by MP2 Performance |
now what exactly do you mean by a plate system? b cuz i was looking at possibly getting an "under manifold" kit.
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
I ran the NOS dry kit (part # 05115-ii) on my 91 GT for years and nobody knew it was there. I had the soleniods mounted in the cowl and snaked the line up to the back of the intake where I drilled and tapped a hole for the nozzle and then put a 7/16" vacuum hose over it. The kit was good for 150hp. On a chassis dyno it actually made a little over 160 horsepower at the wheels.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
mm's nitrous mod
2000 mustang gt
11.79@115.83
plate:
http://store.summitracing.com/partde...5&autoview=sku nossle style: http://store.summitracing.com/partde...5&autoview=sku
so were you using an actual "under manifold" kit, or were you just spraying straight from the back of the manifold? and how big of a cowl did you have? |
an with the plate vs. the nozzle system is there really a difference in performance, or ease of installation? an what brand is best recommended? cuz i heard that zex an venom have some computer, an that stangs like nx better?
#8 | |
1990 Mustang LX
9.36@143 mph
#9 | |
mm's nitrous mod
2000 mustang gt
11.79@115.83
So Darrell, did you just have the nozzle sprayin straight down or @ an angle to spray towards the front of the engine as well?
#11 | |
1990 Mustang LX
9.36@143 mph
so now should i go with a wet or dry system? an is there really a difference anyway?
#13 | |
1990 Mustang LX
9.36@143 mph
so basically just stick wit a dry system?
so now if i do get any nitrous system i should get bigger fuel injectors to be able to add more fuel to the mixture if necessary. correct? not only that but could someone give me a link to a good dry system for about $600 or less and add about 150 horses at most. cuz it sounds like with my luck i would blow up my engine with a wet system.
91YJ 98ZJ 98P71
1998 Mustang GT
Need to hit the track
i'm thinkin about getting nitrous for my auto 98GT. what's the max HP i can go with stock internals and with forged internals? also, what would be a good system for me. i'm thinking of building the car up to about 300HP N/A and then adding the nitrous.
Threads Similar to: Nitrous???
| Nitrous | Goblin | Power Adders | 0 | November 12th, 2007 03:42 PM |
| nitrous | mustangboy8909 | 5.0 Mustangs | 6 | July 29th, 2007 09:33 PM |
| K&N CAI, Nitrous kit, nitrous accessories | Timber | Air/Fuel | 12 | June 28th, 2007 10:35 PM |
| what do you think of nitrous | Badasstang281 | 99-04 | 51 | January 7th, 2007 06:07 AM |
| Nitrous ?'s | bwb3 | 5.0 Mustangs | 5 | November 27th, 2006 04:31 PM |
