Discussing nitrous pressure? in the Power Adders Forum. well i got back from the track last night and my bottle pressure is at ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
nitrous pressure?
well i got back from the track last night and my bottle pressure is at 600 so i bassically cant spray anymore? because i heard its not good to spay less than 900? dunno if thats true or not?
full exhaust custom H pipe,cai, t-spacer, ud pulleys, 75 wet shot of nitrous, mach 1 rims, Xcal 2 custom tuned nitrous 87 93 octane VMP 9.1@80.07in the 1/8th mile.. thats the slow car! 2006 honda cbr 600rr for the fastness!
2004 GT
slow....
yes, it is true.. do you have a bottle heater??
2004 Crimson red GT saleen s/c, full bolt ons |
Sweep the Leg
2003 SVT Cobra
Spraying below 900 isn't bad, but I wouldn't go very much further. 800 would be the all time lowest I would possibly think about spraying. 600 is way too low.
if he does spray its not gonna hurt. the car is gonna be running rich and he just wont get the full shot.. wont hurt though especially if he has a wet kit..
No Homo
7.8@90 (1/8)
So basically 3/4 of the bottle is wasted?
07 GT500 & 2002 GT:
mm's nitrous mod
2000 mustang gt
11.79@115.83
if the pressure is low and its a wet kit, you run into a chance of fuel puddling.
right now, she is a jackstand warrior if the car was a horse, i would shoot it!!! ![]() project warhorse under construction being built by MP2 Performance |
1999 GT
keep it above 1000
![]() Vortech V2-SQ. 3.33" pulley. CAM LTs. MPH Power Pipe. Mac o/r H. Magnaflow c/b. Focus pump. A/A FMIC. 39lb Injectors. KB BAP. 03 Cobra IRS. BF brace. HPX PMAS. Vortech Maxflow Bypass. Dyno Tune Nitrous Wet Kit |
mm's nitrous mod
2000 mustang gt
11.79@115.83
above 900 is ideal, most companies are set up for 950. too low of pressure will be rich and not ideal, too much will be a little lean and can cause some issues as well.
No Homo
7.8@90 (1/8)
How can you keep it up that high? I have a bottle heater but it doesn't help that much and I don't want to buy that nano nitrous assist deal.
07 GT500 & 2002 GT:
Well you have a shitty bottle heater. Mine heats up the bottle to 1100psi in like 10-15 minutes. My bottle heater has a pressure switch on it. When my bottle goes below 900 psi it turns on and it turns off at 1100psi.
No Homo
7.8@90 (1/8)
It's nitrous express. I guess it's just fucked up. Ill check it.
07 GT500 & 2002 GT:
I have a zex wet kit for about 6 mnths and latelly i fill up the bottle get just 1 or two shots 75hps and the nitrous start comming a little disapearing and then i have it again. i went back to the fill up place to ask about it cause i had pressure and everything, but still my nitrous flow kept failing. He told me i should clean up my bottle and take out the little pipe that is inside of it.
Any suggestions? |
#13 | |
#14 | |
Archeat: Nitrous Bottle Heaters
mm's nitrous mod
2000 mustang gt
11.79@115.83
make sure you have all fittings and wires good, i would also check to see if you might have a kink in any part of the nitrous line. i had an issue of my nitrous kicking in and out, i ended up having a small kink. i replaced it and havent had issues with it since. the best heaters will be pressure controlled, the temp controlled ones are ok but not the best.
Look Ma! My First Post!
2004 GT mustang
get you a bottle heater. I am running the dynotune nitrous heater and its very good its not a thermostat heater it monitors pressure and i have mine set at 1150 and it holds 1150 as soon as it drops below the heater kicks on and can get to 200 degrees. works very well.
2004 gt mustang 1. 3.73 gears 2. borla stingers 3. slp x 4. sniper tuner 5. accufab tb and plenum 6. nitrous currently removed awaiting boost best 1/8th 7.8 at 94 |
Threads Similar to: nitrous pressure?
| WTB Nitrous pressure gauge | GreenFaleen | Want to Buy | 3 | March 12th, 2008 04:03 PM |
| nitrous pressure question? | bjesse60 | 99-04 | 7 | December 28th, 2007 01:27 PM |
| K&N CAI, Nitrous kit, nitrous accessories | Timber | Air/Fuel | 12 | June 28th, 2007 10:35 PM |
| Nitrous/ Fuel Pressure??? | acmillr | 99-04 | 42 | January 21st, 2007 02:04 PM |
